  #24
Old Tue, January 12th, 2010, 09:43 PM
bambo2888's Avatar
bambo2888 bambo2888 is offline
bambo2888 is on a distinguished road
Bamboo,
Make sure the PID is set to CHT and not ECT. That 192 sounds more like an ECT.
Its not that I don't believe you but just double check it?
Please.
Yup, CHT it is.
You COULD be a candidate for "lean", but I'm not as sure as 88 is that CHT is really a good indicator. If your load is low (no hills, no high outside temps and no high RPMs, you're not going to see high CHT values. A value of 192 is about what your thermostat is supposed to open at (195 degrees), so it's probably just doing its job. And, Level 2 is a "richer" tune and in gassers, a rich mixture "cools" the engine.
My CHTs tend to stay under 200 (I think) when I'm not towing and just cruising on level ground. If I start climbing, though, they jump to the 210+ region pretty fast. I don't recall seeing anything above 220 though, even on hard tow pulls up mountain passes.
Really though - you WANT the CHT to be in the 195-210 region. This is where the engine operates efficiently and the emissions are lowest.
Fair enough, I guess I'm just suspicious when my truck is working correctly... that doesn't happen to me very often
04 Lariat 5.4 4x4
Gryphon Programmer custom tuned by Bill at PHP ~ 325/60/18 Terra Grapplers ~ K&N Cold Air ~ 2.5 HBS Level ~ Skyjacker Shocks ~ SI/DO Flowmaster 40 w/ deleted rear cats ~ 8000k HID headlights and foglights ~ Blacked out tails ~ Hardwired STI Driver ~ Rockford Fosgate Amp, 10" Sub, w/ Infinity References
BLACKED OUT TAILS FOR SALE!!
