I have noticed when driving real slow under 30 k my truck will hunt. It goes from 800rpm -1300rpm constantly and will not stop unless I let up on the gas pedal. Any thoughts? I also was wondering how much more HP a 2006 F150 has then my 04. The reason I ask is I know a guy who has the same truck as mine 2 years newer and no mods, and we have tried to see who's truck is faster. We start off the line about the same and eventually he pulls away from me, I would have thought I would have had the upper hand. He is running 87 fuel no nothing just stock. My truck has only 35000k his 58000 both are FX4 Screw same engine same everything, even same color,I cant figure this out.
I can't give you a proper technical answer for why your tranny is hunting at that speed..........odd
![]() I'm sure Jack or Bill will figure that out for you but you may have to give more detail as to exactly what's happening. As far as 04 vs. 06..........same horsepower and torque. Here's an important question for you though. Is your truck Canadian or American?......and what size are your wheels? If your truck is Can. and you have 20" wheels........you automatically get a 3.55 gear ratio with 20" wheels! If he only has 18" wheels.....then he would have a 3.73 gear ratio........and Yes - if you raced he would cover you with ease! If this isn't the case......I have no explanation other than variation from truck to truck. But if both have 18" wheels and 3.73's and you are tuned and he isn't........something is really friggen wrong!
08 FX4 CREW K&N 63 series Intake Magnaflow SI/DO exhaust Custom tunes |
I imagine there were a FEW changes between 2004 and 2006 that might account for better performance from the later vehicle. Regardless, I bet if you put two identical trucks from the same year together and raced them, I think one of them(the same one) would always win. Manufacturing simply cannot produce true "clones". One is always going to be slightly better (or worse) than the other. Oops! Chris - you snuck in on me and brought up a point I'd totally ignored! 04FX4's truck is TUNED! Yuk! Now the question is, what is the tune? It may not be set up for the race conditions described. And, yes, I would not have thought the '06s were improved that much over the 04's. But maybe.... 04FX4, have you looked at the HP Torque specs on these beasts from the two model years?- Jack
2024 F150 Platinum SCrew 3.5L PowerBoost FX4, Peragon Tonneau Cover, LineX Bed, 35% Window Tint on All Sides and Rear, Full Nose Paint Protection Film, Husky Mud Guards, Lasfit Floor Liners, VIOFO Dash Cam Last edited by Jackpine; Wed, January 28th, 2009 at 07:31 PM. Reason: Chris woke me up! |
We both have 3:73 gears and he actualy has bigger tires then I do as well. The only mod he had done was install the larger tires and front leveling kit. Should I wait for Bill to post or should I call him? Thanks
Now, everyone - tell me how full of **** I really am! ![]() - Jack |
I thought it took more HP and TQ to make the bigger tires turn. If that is true I should have the upper hand, but definitely do not.
I was thinking of calling Bill, but I know how busy he is maybe I will call him from work tomorrow.
You SHOULD be able to pull away from him a bit at the start (of course you have to be careful not to spin the tires - he won't have as big a problem in this region with tire spinning). And, I COULD be "full of it"! (And it won't be the first time). :o Be interesting to hear what Bill has to say.- Jack |
That is really weird that your truck doesn't win. I know the 4.6 engines gained more horsepower in the newer years, but according to vehix both the 04 and 06 have 300hp and 365 ft/lb. Yours should beat his off the line, since his has a lower ratio now, but I know my 94 2.3 Ranger with 33's and 4.56 would take my buddies 05 3.0 Ranger with stock everything til about 45 mph, I really thought his would just beat mine all over.
Is it hunting in between gears?
2000 Black Excursion, Two 400hp 7.3 blocks with windows
