  #13
Old Fri, April 23rd, 2010, 09:12 AM
How did you have the subs hooked up? There are 2 popular ways to do it and one has more power but will overheat an amp QUICK.
+1,-1 is positive and negative connections for sub #1,
+2, -2 is positive and negative connections for sub #2
This is for a 2 channel amp but I'm not sure if thats what your using. the tabs to connect the wires are this little symbol, [. A 2 channel amp has 4 little tabs, 3 channel has 6, etc.
For standard hookup, this will generally work the best.
-[...-1
+[..+1
-[...-2
+[..+2
This is for "bridging". Bridging will have a slightly higher output but the amp will heat up WAY faster. Also, not all amps are bridgable.
-[...-1,-2
+[...+1,+2
To help keep the amp cool a friend of mine made a small box that fit around his amp and he mounted computer fans on it to move air.
What watt are the subs(is it one 500 watt sub or 2 250s) and what watt is the amp? You said 500 watt sub but I thought you were running two subs.
