  #11
Old Thu, February 12th, 2009, 11:25 PM
What I really think is that Bill needs about five alter egos so he can jump in and help you figure out the problem.
I can't believe you'd have oil pressure problems on a new truck. And, if that were the case, the problem would not go away when you returned it to stock. Are you trying to adjust "Custom Options" when you set in a program?
If none of this applies, and if there are no problems running at Level 0, I have to believe the tune is causing the problem.
If you agree, I think you should call Bill ASAP.
