Old Wed, December 29th, 2010, 10:11 AM
Originally Posted by Jim Allen View Post
Thanks. That leads me to wonder... do you get more time the fewer the parameters you choose? Because I have a bunch of other instruments, the readouts of which I can also datalog, such as coolant temp, oil pressure, etc, using an Isspro Performax system. I really only need two parameters, EOT and VCT. The other info, including actual coolant temp (not interpolated CHT).
My name is Jim... and I'm a gaugeohaulic!
Yes but no, the less PIDs greatly increases the log time but there is no way for you to select less PIDs. The stock edge programmers record 6 PIDs for about a minute but Bill made some changes on the gryphons and it is 5 Pids for about 5 minutes, but he may have also adjusted the amount of memory that is taken up for datalogging. Are you positive your truck reads the EOT? Mine only uses CHT because the EOT ALWAYS reads zero on the gryphon making datalogging that PID impossible.
Hey, I recognize that picture.
Definitely makes mine look inferior.
Where did you get the tray mounts for those two lower guages and how did you route the wires? I'm assuming you drilled a hole and routed it down above the CD player.
