Old Thu, January 20th, 2011, 08:45 PM
FARMBOY22 FARMBOY22 is offline
FARMBOY22 is on a distinguished road
Question BIG A CODE INJECTORS?
I was curious how large cc wise an A code injectors can be built. Reason being it seems to me the higher injection pres of the A code would up the mileage and perfromance of an engine even though you would need more oil. Especially if you had a weak pump and were going to replace anyways. Would an 200cc/100% full A code not out perform a hybrid the same size? How much more oil would the A code need?
WHEN IN DOUBT FLOOR IT!
IF IT'S TOO LOUD YOUR TOO OLD!
99.5' F-250 EXTCAB 4X4 6SPD 4" LIFT 35" TIRES 3.73 GEARS
K&N INTAKE, GTP38R W/TURBO MASTER WASTEGATE CONTROLLER,
203DEG THERMOSTAT, EVO II,AND MBRP COOL DUALS EXHAUST NO MUFFLER
