  #12
Old Thu, March 10th, 2011, 03:48 PM
God & Guns
Originally Posted by roary View Post
Just curious, but what are you planning on putting the "big truck turbo" on? And are you meaning a Semi truck turbo?
My truck.... and yes, it came off a semi or a heavy equipment diesel. I seen someone that took one off a cummins semi and fabricated the setup. They moved the passenger side battery tray (relocated the battery) and set-up the turbo there. Not sure how they plumbed it, but it worked with the stock/aftermarket turbo that was already on it.
