Old Wed, May 11th, 2011, 10:59 PM
One thing I do with mine is to remove the box and use that small grounding tab (on the lower 7MM bolt) to keep the PCM up against the firewall. This also acts as a case ground for the PCM.......whether its necessary or not - I could not tell you.
