Old Sun, May 29th, 2011, 02:46 PM
Lowdown89 Lowdown89 is offline
EVERYDAY HUSTLER
Lowdown89 is on a distinguished road
Default My engine build thanks to Bill,Cody and Brad
I thought I posted these pictures but guess I didn't here are the pictures from the build.... Bill and Cody did a AWESOME job on it!
ok, so this all started as a simple take the heads off have them cleaned up and put studs in along with new turbo,injectors, HPOP, and fuel system... what it turned into was a complete engine rebuild after Bill found a good bit of damage to my rockers,valves and pistons... just figured i would share some of the highlights of the build with yall
on the trailer headed to GA for Bill to work his magic!!
engine is out and ready to find out whats going on
the turbo has seen better days!!!! it seems squirrels made a next in my intake while i had the truck parked for a while!!!!
Cody tearing the engine apart
almost coompletely tore down
think the valves need replacing??
piston damage!!
kinda hard to see but showing the cylinder wear
cleaned up and ready to start going back together
looking like an engine again
getting there!!
shot of the Adrenaline pump and CPR fuel system
better shot...
everything back together and back in the truck
close up of fuel bowl delete and new fuel filter
CPR fuel pressure regulator mounted
on the dyno breaking in the engine
and its done!!!
First of i have to give HUGE props to Bill,Brad and Cody From Power Hungry Performance, they have done an awesome job and are absolute pleasure to work with!! 2nd i got to thank Bob Riley at dieselsite for everything from answering all my dumb questions and always being on top of getting bill parts as soon as i would order them LOL, and Clay at RiffRaff for the awesome deal on the turbo.... and also thanks to everyone who i have bugged and bothered while i was gathering parts to get this underway!!!!
The truck made 396hp and 867ft lbs which I was pretty happy with I can't wait to get a built trans so I can spend even more money for my eventual goal of around 550hp
