  #12
Old Fri, July 22nd, 2011, 11:22 PM
Because of limitations in the TS chips, we have to disable PATS in the Excursion. In order to prevent the theft light from blinking, disconnect the plug from the PATS module. The module is located below the dash, just to the right of the accelerator pedal and should have a red plug on the bottom of it. Just disconnect and the light goes out.
Yes, a standard key will work now.
