Old Sun, September 25th, 2011, 08:55 PM
God & Guns
Ok, I've been under the truck a little today installing the new egt probe (didn't fix my gauge issue) and took a look at the drive shaft. The ujoints themselves look like rust. Anyways, found that the rear drive shaft boot is missing. So I will be taking the truck to the alignment shop to have them to replace all ujoints and have them grease everything up. would it be worth it to have the drive shaft balanced?
