Old Wed, October 5th, 2011, 08:52 AM
cj45lc cj45lc is offline
Originally Posted by ttyR2 View Post
Is the horsepower "limitation" on stick shift trucks merely because you can't keep boost up between shifts like you can with an auto? I'd assume if you're in one gear for a while, pulling hard, a stick truck should make just as much horsepower as an auto.
the stick will make the same HP as the auto, the HP limiting factor is the injectors. I believe that was what Cody was saying that with a truck with stock injectors the max HP gain would be around 100HP stick or auto
