Old Mon, October 24th, 2011, 03:39 PM
God & Guns
"Have them check the brake line going to the rear axle where it passes behind the fuel tank on the driverside frame rail. Mine rusted out a few months back & gave the same symptom you describe."
Would you not use brake fluid with that issue?
