Old Mon, April 2nd, 2012, 09:57 PM
God & Guns
I don't know if a Ford dealer can tell if the pcm has a tune on it. A chip plugs into the opening and has a long wire with a knob at the end. If it does have a program flashed to the pcm, a chip will overide the flashed tune. But you would never be stock again which could cause problems with diagnostics or if you have to pass an emissions test.
