Old Thu, December 30th, 2021, 09:56 AM
Originally Posted by Powerstroke Cowboy View Post
Bill, have you tuned any pickups with pulsars GTP38R turbo? If so how has it done?
I have not specifically. However, one thing you want to do with tuning any larger turbo is back the ICP and timing down a touch to help get the turbo spooled. Too much ICP and/or timing at low RPM tends to reduce the amount of heat energy in the exhaust and makes the turbo a little laggy off the line. Reduced timing helps low end torque and improves the spool of the turbo. Once RPMs come up, normal timing and ICP curves are fine.
Tags
38r, 7.3l, diesel, dieselsite, ford, power, stroke, test, turbo, wheel, wicked
