#21
2005 F150 XLT SuperCab 5.4L V8 4x4, 3.73 LS Rear end, Auto Spring 2" Leveling Kit, Gryphon tuner custom 87 Performance tune, AEM Panel Air filter with modified stock intake, 14" Magnaflow muffler |
#22
Henry 2011 F150 FX4 5.0, 3.73... |
#23
All I know is, I moved several tons of snow from my driveway and walkway when I was stationed in Pennsylvania, then got to move several tons more when the snowplow came by and put up a wall between me and the street! :cry: When we left Pennsylvania, I left my snow shovel as a "housewarming" present for the new owners! ![]() I would have guessed though that 4 low would be the gearing of choice. Again, shows what I know - nothing! But, I bet Bill can take all these (sometimes conflicting) requirements into account and he'll give you what you need. You should post some pictures of your rig. Heck, I should do the same! ![]() - Jack |
#24
This is my truck.
#25
That's a pretty impressive piece of hardware, Henry!
However, it looks to me like it doesn't really block the airflow into the radiator much at all. I suspect any overheating you'd get would be due to running at high RPMs and very low forward speed. Still, you're performing this operation in winter, when the air is cold, so I'd expect things to stay relatively cool. One thing nice: with the Gryphon you can monitor your Cylinder Head Temp (CHT), Oil Temp and Transmission Fluid Temp (TFT) and you'll get a digital readout that tells you exactly how hot things are getting. I wouldn't even bother with the Coolant Temp. It's not actually measured at all but is inferred from the CHT. Don't be surprised when you see the oil temp go up quickly when the engine is under load. Mine shoots up close to 250 degrees when I'm pulling my trailer up a long incline in a lower gear range, but the CHT stays around 212-214 under those conditions. - Jack |
#26
That thing is awesome! I'd like to have one here in Texas just to see how people react.
04 Screw Lariat--Magnaflow SI/SO-- PHP Gryphon--AS 2"--BFG ATs 285/65/18-- Silverstar Heads and Fogs |
#27
Thanks for the compliments on my truck. It's the second best F150 I've owned so far. My 89 F150 Custom work truck was the best.
This plow isn't heavy compared to other plows. It's a SD (standard duty) Fisher that weighs in just shy of 500 pounds. Fisher's MM2 mount is great. Drive into the pickup points, flip up the lever, push the upper frame into the truck, connect the 3 plugs and lift up the jack post and your set to plow. Sure beats the old days of having to almost climb under some trucks to put in or pull out pins. My reference to heat comes from the factory outside temp gauge. As I'm sure you know the temp sensor is located on the support post in front of the middle of the radiator. One day when I was paying attention to things, the outside temp was 10. With the plow on and driving down the road, the outside temp sensor indicated it was 48. So, my thought is, we need to pay attention to the amount of added heat performance tuning may give. Heck, as my wife reminds me, I drive like Grandpa Walton, so it's not too often that the revs go very high. Any chance of another sale? Time to put the plow on we've got another storm brewing for today.
#28
Where on Long Island? I grew up in East Brentwood and now reside in Fort Lauderdale:sniffle:
#29
Well it's finally official, well almost, I just sent my order in for custom tuning for my truck. Can't wait to check it out!!!
