Old Sun, May 6th, 2012, 09:17 PM
God & Guns
Originally Posted by INFRNL View Post
I have never been on a dyno. I think our truck are around 235/250 at the flywheel, so probably under 200 at the wheels. 80/120hp from the chip, but I am not sure how much power we actually get from the chip. SO I guess we are somewhere near 300. That sucks, 100-150 more on PMR's probably isn't enough
When I make my calls this week about turbo's I think I will ask about upgrading the motor, just for grins. Maybe this year I will max out the PMR's and save to get mor power next year.
I am not sure what the Black Mamba motor is, but will look into it. Thinking a short block might be the best route. Then we can upgrade our existing blocks for backup.
I saw someone on TDS that advertised their emissions results, and they also ran their truck on the 80hp DP tune. The dyno wasn't exactly calibrated, but they saw a gain of almost 40hp.
When it comes to upgrade my turbo I'm gonna come talk to you. You been doing some in depth research....I'm interested in seeing what you go with. I'm sure you saw that post on TDS about max boisterous with what chip/tune/turbo/injectors. I think people using phP tunes were reporting more boost : )
I tried finding the Black Mamba engine, by The Horsepower Shop, on my ohone and couldnt find it...hopefully they ate still out there. I like the short block idea.
How do you like the RiffRaff FRx? I'm thinking about buying it, tonight possibly...depending on if you post back tonight with good praise of it.
Old Mon, May 7th, 2012, 12:12 AM
INFRNL INFRNL is offline
I saw that post about 80E only getting 40HP. Thats why I thikn TW doesn't post HP ratings. I am curious how bills will compare. I hear in the end that all 3 tuners are very close in HP but tune differently.
I found some info on the black mamba. I also saw some threads on different forums stating to steer clear of them. I am not sure; will have to do more homework. Wide open perfomance are selling built long blocks from 10K+ Might even go to pull and pay and get a full motor for cheap.
; If I can find forged rod block.
the more I research on turbos, the more confused I get. I need to learn how they work and the difference in impeller sizes.
as far as the FRx. On my truck I cannot feel or hear a difference at all, but was told its more for saving the injectors. It keeps the air out of the fuel so the injectors do not have to force the air through them and prolonging their life.
There is a thread on TDS about the FRx. I think the guy was extremely happ and claims to feel/hear a difference. I already have the intank mods done, so that might be a reason whY I cannot tell a difference.
Its a cool low cost alternative to the full kits offered. Would I do it again...not sure. Honestly If I started over; I probably would not do most of what I have done to this truck.
I think my truck is louder now too since I changed the ICP? the one by the intake plenums. I will have to put my old one back in and see. Its that or the IPR on the HPOP that made it louder. When Warm My truck was pretty quiet. Or maybe my old ones were getting faulty and I have more pressure now making it louder cause its working better, IDK.
Old Tue, May 15th, 2012, 12:03 AM
If I do have pmr's, I'm gonna save my lunch money until I can take it to the PHP shop and have them install forged rods, springs, rods, turbo injectors, fuel system, and maybe bigger hpop.
Talked to Bill last week about building an engine; approx 7K without rods. depending on rods chosen would be additional, but would have a near bulletproof motor.
I am wondering if factory forged rods would be good enough or something aftermarket.
Also ; as you know I figured out my turbo and injectors
Next will be HPOP and to upgrade my fuel system. I also need a steering gear box and power steering pump
Old Tue, May 15th, 2012, 12:24 PM
God & Guns
I'd be crying over my wallet by now
I'm looking at a house this evening when I leave work. I may have to put a hold on spending for a minute.
I have done quite a bit of catching up on my truck spending in the last month. Makes me feel all warm inside
Old Tue, May 15th, 2012, 09:20 PM
I hear you; If my wife knew how much I have spent on the truck lately She would have a heart attack and kill me in my sleep
I have a few more things I want to do; then I will be done for the year...........
I think
Old Wed, May 16th, 2012, 08:07 AM
God & Guns
I think
yea, I was wondering how was you getting by with all of that spending. My wife has told me a couple of times that I should just marry the truck.
Old Wed, May 16th, 2012, 08:51 PM
I think I am getting to that point as well.
Too bad you already ordered your up-pipes; could have sold you mine for much less. I won't be needing them once I get that new turbo setup; unless I get a 38R for comparison/backup
Old Thu, May 17th, 2012, 12:36 PM
God & Guns
I was thinking the same thing when I saw your post on TDS. Also the FRx, which I ordered 2 weeks ago. Oh well...
Old Thu, May 17th, 2012, 06:56 PM
If I knew I was going to get crazy; I would have let you known earlier Could have made you a great deal. Too late now.
I need to get Tony's tunes from Bill I know bill has been busy and Tony has been hard to get a hold of. bad thing is I will have everything in a few weeks. Maybe I will try to get a hold of Bill; Maybe I should try and get Tony's tunes setup for my upgrades instead.
