Old Mon, February 23rd, 2009, 08:11 PM
Caforddude Caforddude is offline
Cali Gestapo!
Caforddude is on a distinguished road
Welp the truck went into a NEW dealership today. Has been my second choice behind DREW for some time laziness prevented me fromtaking it there in the first place.
Service adviser called me at noon today saying she and the service manager had taken it for a test drive to see if the problem could be duplicated and her response was "OH MY GOD I DIDN"T KNOW IF WE WOULD MAKE IT BACK TO THE DEALERSHIP"
They did some sort of "pinpoint" test she called it and determined there were no electrical issues. First thing in the morning they are going to pull the valve covers off and check a solenoid? to see if it is working. If that is the problem then a replacement and I'll be good to go. If not then appaerntly they tear the engine down enough to pull the cam phasers and cams?
Either way my truck has been there since about 10am and I have gotten 3 calls. One to let me know it got there ok, 1 to let me know the results of the test drive and 1 a few ago to let me know they finished the electrical testing and would be pulling the valves tomorrow. Total time on the phone with the service writer....About 3 minutes. Is that too much to ask?
Glad to see Customer service IS still alive.
I'll keep ya posted.
Aaron
For he is the minister of God to thee for good. But if thou do that which is evil, be afraid; for he beareth not the
sword in vain: for he is the minister of God, a revenger to execute wrath upon him that doeth evil. Romans 13:4
  #42
Old Mon, February 23rd, 2009, 08:20 PM
Sounds like you've found the right dealer! Good on you and good on them!
Old Mon, February 23rd, 2009, 09:46 PM
Okay did anyone at any time perform a viscosity test on the oil?
Fords are some of the pickiest vehicles on the market for needing the right oil.
Put the wrong stuff in either wrong weight or vicosity and you will eventually end up with problems.
Our engines are grand kids to the GT 40 and IRL.
On the heads the cams have hydralic timing dampeners. These allow the motor to have more torque on the low end. Putting a heavier oil in like 10w is enough to not allow the proper oil flow and so potential plugging of the tiny oil ports might happen or insufficient oil equals premature rapid acceleration of wear.
Maybe a newbee at walley world messed up to begin with. Put the wrong barrel on the wrong feed hose or maybe the wrong oil period.
Another thing to think of when getting oil for changing is to make sure it meets fords specs.
Another thought maybe bad cams or chains or sensors.
But I feel the viscosity test was important if that was the problem. Walley world would have had to foot the bill.
  #44
Old Mon, February 23rd, 2009, 09:55 PM
Cali Gestapo!
No testing of oil done as far as I know. First dealer changed oil and claimed "brown and gritty" but I am now doubting that claim. It does not show up on any paperwork or diagnosis. Nothing was made of the Fram oil filter it had on it either. Now it has fresh motorcraft oil and a motorcraft filter. If that was the problem I'm guessing it would be hard to prove or even confidently say that at this point.
Aaron
  #45
Old Tue, February 24th, 2009, 12:30 AM
If you brought a vehicle into the dealer here with those codes. The viscocity tests is one of their tried and true tests to get out of a warranty claim. But that is just one of their many process of elimination proceedures.
And to my understanding there is more people out there running the wrong weight or less than spec oil.
There are so many variables in this situation.
My rules on oil changes
1). I buy the oil and filter.
2). I do the change or bring it to a place where I supervise.
3). Viscosity tests are done on both new and used oil.
4). For whatever reason the vehicle never leaves my sight!!!
5). Anything dropped on floor gets inspected thoroly. If oil filter gets dropped that one is thrown, and another new one comes out of the box.
6) Always check dipstick for oil before departing service center.
Sounds kind of anal doesn't it. Sometimes other peoples mistakes will haunt you for the rest of your life.
Lars.
  #46
Old Tue, February 24th, 2009, 12:49 AM
Cali Gestapo!
I'll find out tomorrow what the dealership says.
Aaron
  #47
Old Wed, February 25th, 2009, 10:26 PM
Cali Gestapo!
So far they had it checked out electricaly on Monday and it checked OK. Tuesday they had a down day because of a prior, more pressing truck they had been waiting for parts to.
Today I guess they took the valve covers off.
Cam's look good, phasers look lined up. No scarring, chaffing or whatever on the heads. Said there is NO indication maintance or abuse is an issue. Service writer said "Heads don't lie"
They did find they have a loss of oil pressure somewhere, they are going to try and pinpoint tomorrow. Said the noise I heard was metal on metal from lack of lubrication due to a failure somewhere. Looking at the oil pump I guess tomorrow. Service writer said it could be it failed/failing causing the low oil pressure. Funny thing is I NEVER got an idiot light and it always checked "OK" when I ran the onboard status check thing.
Said worst case scenario is a new engine, that was what they had to do last time she saw a similar situation. Best case scenario is oil pump and replace any associated parts.
Either way it is me and the Chevy Impala for at least a few more days.
Said she had every indication based on what she saw and has been told that this will be a warranty issue.
Aaron
  #48
Old Wed, February 25th, 2009, 10:31 PM
JWBFX4 JWBFX4 is offline
Hopefully this dealership will get you fixed up as good as new, sucks to read about all of the problems you have been having...good luck dude
  #49
Old Wed, February 25th, 2009, 10:37 PM
There's a reason we call it the "Idiot Light"! It won't show a problem until about 5-8 psi. Can you imagine how much damage you can do with pressure that low? It's crazy.
Glad to hear Ford is stepping up and fixing it. I know where you'll be going (not to mention recommending) from now.
  #50
Old Wed, February 25th, 2009, 10:42 PM
Cali Gestapo!
I am cautiously optimistic....
They have some more tests to do tomorrow to figure EXACTLY what the problem is/was.
Just by chance they have a Ford engineer coming to the dealership tomorrow so they will get his input also.
What she said was that if she did not think this was going to be a warranty issue she would have asked for money before they went any further...
Like I said it ain't a done deal yet but...
Aaron
