Old Wed, February 11th, 2009, 09:26 PM
Caforddude Caforddude is offline
Cali Gestapo!
Caforddude is on a distinguished road
2007 F150 5.4L with Gryphon
I currently have a Gryphon and am running the 87 performance tune.
Ok so earlier this week I started hearing wat sounded like a little rattling noise at certain RPM's. I assumed a loose exhaust clamp or something simple I could do when I had the weekend off. Truck has also been hard to start. I assumed maybe needed a new battery even though mine is only 2 years old
Today I was running low on gas and pumped in some 91 octane, only about 5 gallons. Drove home and idle at lights seemed a little rough. Picked up my daughter and headed home. Get home and stop just outside the garage to let my daughter out. Start to pull into the garage and engine starts running REALLY rough. Bouncing between 3-500 RPM's, low based on what I have seen.
Pull the code and I get:
P0012 Intake Camshaft
Position timing
over retarded (bank 1)
Code looked exactly as posted above.
Tune issue? octane issue? Other issue? Any help would be greatly appreciated. I am heading to the snow this weekend and do not want to get stuck up there...
Thanks.
Aaron
For he is the minister of God to thee for good. But if thou do that which is evil, be afraid; for he beareth not the
sword in vain: for he is the minister of God, a revenger to execute wrath upon him that doeth evil. Romans 13:4
Old Wed, February 11th, 2009, 10:09 PM
Cali Gestapo!
I have been running it since I got my custom tunes.
I looked back at my emails and it looks like you notified me on 01-04 about them being ready, so shortly after that.
Aaron
04FX4 04FX4 is offline
Try and return to stock?
Old Wed, February 11th, 2009, 10:10 PM
Cali Gestapo!
Have not tried to return to stock yet...Wanted to wait for some input first.
Aaron
Old Wed, February 11th, 2009, 10:11 PM
Grabber523's Avatar
Your Mom's favorite :D
How many miles on your truck? What weight oil you running? How often do you change it? Sounds like a cam phaser failing, take it to the Stealership. Common issue on the modular engines because they are oil pressure actuated and any crud in the journals will cause them to stick in the default position due to lack of flow and pressure.
EDIT: IF it were a tune issue it would have happened immediately after you uploaded the calibration.
Old Wed, February 11th, 2009, 10:18 PM
Cali Gestapo!
32xxx miles on the truck. Mods in the sig. whatever the reccomended oil is the oil change place put in. Changed every 4000 miles or so
Aaron
Old Wed, February 11th, 2009, 10:32 PM
Grabber523's Avatar
Sounds like you're doing everything right, and still under warranty. I'd take it in to Ford and have them look at it.
Old Wed, February 11th, 2009, 10:40 PM
Northern Supercrew's Avatar
Northern Supercrew Northern Supercrew is offline
working for parts.....
Northern Supercrew is on a distinguished road
That looks exactly like the code that came up on mine about a week ago...i'm running the 87 perf too. i returned to stock and then checked for codes again, and none came up...i then reloaded the 87 perf tune and no codes again...still running it with no probs.
2008 f150 supercrew, 5.4, 3.73 LSD, tonneau cover, 275-65-18 BFG's. Gryphon programmer. XLT with XTR package. Tinted heads and tails with 8000 HID's. 4300 in the fogs. Gott's Mod. Painted grill.
Old Wed, February 11th, 2009, 10:43 PM
Cali Gestapo!
hmmm..That gives me hope of a computer glitch? simple fix... Did you run for any length of time on the stock program before going back to the 87 performance or just load them back to back?
Aaron
Old Wed, February 11th, 2009, 10:48 PM
no run time at all...i got to work and shut off the truck and installed stock tune right away..checked for codes and then left it for the day...next morning installed 87 perf again. my codes came up as yours but bank 2 also. went really gutless...thought the fuel filter was gumming up kinda feeling. and would not rev over 3000 rpm.
