Old Tue, April 25th, 2023, 10:29 AM
jimminy jimminy is offline
jimminy is on a distinguished road
Default Changing tunes
What is the recommended way to change tunes? can you change from tune to tune as you drive down the road? or do you have to stop and change? or do you have to turn the ignition to just on to change tunes. I looked but can't find any info on this. Thanks
Old Wed, April 26th, 2023, 11:01 AM
What platform or device are you using? The hardware that you're using will dictate how it functions.
Old Wed, April 26th, 2023, 02:19 PM
I have a 2002 f250 7.3. The tuner I installed is the Hydra.
Old Wed, April 26th, 2023, 08:20 PM
There is no reason to stop the vehicle or engine when changing tunes so long as all of the calibrations "burned" to the Hydra are of the same calibration family.
It is not recommended to change them on acceleration or when doing something such as driving through an intersection, railroad crossing, or the drive through JUST IN CASE a stall occurs (rare).
Old Wed, April 26th, 2023, 09:22 PM
Sounds good, thanks for the reply. Full Force set it up before they sent it to me so all calibrations should be spot on. Thanks again!
