Old Thu, March 6th, 2025, 02:06 PM
Sponsonhead Sponsonhead is offline
Sponsonhead is on a distinguished road
Default P1211 code
I have a 2000 7.3 Excursion with 268k miles on it, running a Hydra chip and an Edge CTS 3 to monitor things. I have notice that when I am running tunes (PHP 80 hp Daily driven, or PHP 80 hp Moderate to light tow when pulling a 23‘ Airstream), if my ICP gets much over 3000 the truck throws a P1211 code. It seems to run ok in spite of this.
If I don’t activate the chip, I get no code, but I get typically 2-4 mpg less on my mileage. I have replaced the ICP and IPR sensors with new OEM parts, with the same result.
My question is, can I continue to run with the P1211 code popping up from time to time when I am on the chip and just ignore the code, and this is just a byproduct of running the chip, or am I doing damage to the engine? I should also mention I am running stock injectors.
Thanks in advance.
Old Fri, March 7th, 2025, 08:12 AM
As a rule, we don't like to see any codes or CEL events. If you're seeing a CEL and/or P1211 when the ICP crests 3000 PSI, there might be something in the tuning that is not responding correctly. In general, our tuning will allow for up to 3250-3300 PSI without setting a DTC.
If you could, please let me know what calibration code you are running and I'll be happy to take a look at it and see if there is something we can do about the DTC?
Thanks!
Old Fri, March 7th, 2025, 09:38 AM
Thanks for responding. The calibration code I am running is VNAB1Y2.
