Old Sun, April 26th, 2009, 09:57 PM
twintips_17's Avatar
Let the Mud come!!!
Default Still cant figure it out.....
Some of you might remember me from a thread i started titled, SO far nothing but problems (http://dygytalworld.ehost-services13...read.php?t=587)
I listed the thread but I was having problems "custom tuning" my gryphon. Well I kind of just forgot about the problem as it wasn't too big of a deal but it hit me again this week when I went to have some fun. I changed my tune from the towing to the performance tune. Did a couple of 0-60's and then went to go back to my old tune.
I brought the menu up like always and went through everything and hit load last settings (or whatever it says on the last line) and it went into a sputter. Not a no start but it wouldn't run right. It was VERY rough. So I retuned it back the 87 tow and it was fine.
Advanced my timing to 91 octane on the 87 tow tune and it again went to sputtering.
I know the fuel I am buying is good 91. I have search everywhere for non-ethanol fuel. I’m the only one to put fuel in my truck ever. So I know what I have in it.
It just strikes me as odd that I can be running fine on a canned tow tune that is tweaked. Go to a performance tune for 15 min. and try to reload the same tune and it gives me a rough idle. If I didn't feed it gas it would die.
Another thing is that it doesn't reset the AMPG. I hit enter twice and it just won’t. Is this something i missed that is different from the edge?
I hope my tow tune to get here soon so I truly run on 91. As of right now i am tuned for 87 but running 91 I can’t get any alterations to any program to work....
I tried just to change the tire size and it went to a sputtering start...... That really confused me.....
Any help.....
SUPERcrew
AF1, EDGE, and EFANS with Magnaflow Exhast SISO.
Expy Console and Rear Seat Swap! Eagle 16's with 285-75/16 ST's
Gryphon Tuner soon to have custom tunes by PHP!
Old Sun, April 26th, 2009, 11:43 PM
This sounds like you were in the Custom Options menu? The "Load Previous Settings" step is the FIRST thing you want to do if you want to recover your saved tire size, gear ratio, WOT shift points, etc.
When you are finished after this (after any additional settings you make), you scroll to "Done" and hit <Enter> , then sit back and let your Gryphon program the PCM.
Again, you first want to "Load Previous Settings" BEFORE you make any changes. The changes will overwrite portions of the previous settings and previous settings will "wipe out" any new changes you have just entered, but not programmed into the PCM. And if you advance the timing and program the PCM, that value becomes embedded into your "Previous Settings". It would not be correct if you went back to 87 octane gas.
It sounds like you may be doing the "Previous Settings" step out of sequence. You're not really reloading your previous tow tune.
You're on the main display screen when you do this? Have you tried changing the "click rate" (to use a mouse button description)? In other words, increase or decrease the pause time between pushes on the <Enter> button?
Any help.....
Again, I think you are doing the "Load Previous Settings" step out of order. Do it first - right after you go into Custom Options. Then, because things are clearly screwed up, go through each and EVERY one of your custom options! Make sure they are correct - especially the timing (it should be no more than +2 degrees) for 91 octane gas on an 87 octane tune. When you finish, scroll to "Done" and hit <Enter> to start the programming process. It will take quite a while. Make sure your battery is at full charge. Leaving a trickle charger on it as you do this would not hurt. Make sure your AC blower, radio and headlights are off too.
Hopefully, this will get things back the way they should be. Let me know what happens, OK?
Old Mon, April 27th, 2009, 12:11 AM
Let the Mud come!!!
Jack,
I have always turned everything off. I shut the doors, and program everything without even leaving the truck. I didn't change anything. I went straight down and hit the load previous settings. In the past i have tried just making simple changes. I would just load a tire change and it will give me wierd outcomes. I owuld leave all the shift points and timing untouched but yet it will always give me a rough idle.
I have only done hte Previous options thing once. Every other time I try to do a custom tune. I have yet not been able to make any changes to a tune.
Period.
This is what i have tried in the past from day one with gryphon. Every tune.
1.) Loaded 91 performance....
Wouldn't run. Would start and then just die....
2.) Loaded Tow tune with timing advanced 2.0.
Ran but was rough.
Had to get home so i tried a tune without changing things.
3.) Loaded stock tow tune.
Worked great. Was better then changed Canned tune on edge.
I then ran this for about a week.
4.) Tried tow tune with just the tire change.
Read in manual to cross referance size. I put it in. Hit done. Rough idle.
5.) Went back to tow tune.
Ran 87 tow tune on 91 gas for 2 months.
Decided to have some fun and try the 91 tune again.
Loaded and started. Ran great. Did my runs.
6.) Loaded tow tune.
ONLY change was advancing the timing +2.0 for 91 octane fuel.
Rough idle.
Went back to canned 87 tow tune.
Thats where i am now.
Sorry if it is so long. But that is a step by step of the last 2.5 months since i have had my gryphon.
I had my edge for 3 years and never once had a problem programming it. The steps are the same for the gryphon, so i would assume we could rule that out.
I will try to change the click rate and see if that helps. I hope it does.
Nate
Old Mon, April 27th, 2009, 11:13 AM
Thank you Nate - I finally understand, I think! :o Sorry it took me so long.
As long as you do not try to apply any Custom Options, things are fine - does that about sum it up?
Of course this is way above my limited knowledge of the Gryphon and I suspect there COULD be a problem in the firmware of the unit. I'm sure Bill can correct this, once he finds the time to get back to you. We've alerted him through the moderator's network about this so it hopefully won't get lost in the "shuffle".
As you know, Bill and Corey are possibly out of touch since they're on a live tuning trip, so it may take a couple of days for them to get back to you. Hang in there!
Old Mon, April 27th, 2009, 06:36 PM
Let the Mud come!!!
Thats what i think it might be. And yes you are correct in saying that "ANY" custom option throws it into a rough idle. I dont know how they drive but i cant imagine it any better than the rough idle. It feals like it runs on 4 cylinders.
Anyways. Like i said i should be getting my custom tow tune from them soon.... So its not to important of a problem but none the less it still isn't great. There are times i really need to change some of the options.
Thanks Jack for you help once again.
SUPERcrew
