Old Mon, May 11th, 2009, 02:48 AM
DOD 4.6 DOD 4.6 is offline
DOD 4.6 is on a distinguished road
Default HELP! not finding PCM
so i did some electrical work on the truck yesterday and i unhooked the battery. I left the gryphon plugged in and when i turned the truck back on the programmer says it cannot read the pcm. i believe it said error F1. any help to get back to normal would be greatly appreciated. the truck obviously still runs great but i cannot read anything on the display because of the error message. please help
2005 4.6L flareside supercab 2wd 3.73 LS
Goodyear 275/55R20, ROUSH 20" wheels, Eibach 2/3 Pro Truck kit, Gryphon canned tunes, ROUSH O/R exhaust, Gotts intake with K&N filter, FF Dynamics 6000cfm electric fans, Pilot 55w fogs, ROUSH grill
Old Mon, May 11th, 2009, 08:06 AM
OneTomcat's Avatar
PHP Cheerleading Section
You can try this.....unplug the Gryphon, turn the key to the on position (but don't start vehicle), plug Gryphon back in and this should re-initialize your programmer in 15-20 seconds or so.
'05 F150 FX4 SCAB
K&N FIPK
Magellan Navigation System
4UCam wireless backup cam
Old Mon, May 11th, 2009, 09:46 AM
Very good OneTom - that's exactly what he should do!
Old Mon, May 11th, 2009, 01:21 PM
thanks. you guys are awesome!
Old Mon, May 11th, 2009, 01:26 PM
Cool! Glad it worked! Just so you'll know, I did something like that once. Disconnected the battery with the Gryphon connected, then reconnected the battery and was horrified when I saw the Gryphon's screen as I turned the ignition on. But then I remembered that disconnecting the battery is sort of like unplugging the Gryphon. The ignition has to be on before you plug it back in!
After a while, we all get smart enough to figure everything out. :o
Old Mon, May 11th, 2009, 10:04 PM
Thanks again guys and gals. I was doing the permanent wiring for my e fans and completely forgot about the gryphon (and how could i right). i guess i should have looked in the manual first and did a search on here
Old Mon, May 11th, 2009, 11:58 PM
Tell us how the e-fans work out for you, please?
Old Tue, May 12th, 2009, 11:50 AM
The efans are a nice bolt on. I have more low and high rpm power. especially the higher rpms. The air conditioning is freezing now. im not sure how many mpg i gained, but the fuel needle is noticeably slower. engine revs quicker. the steering is a little tighter, but this makes the steering response feel more sporty. here is a direct link http://ffdynamics.com/f15034B.html. the kit has everything you would need
