Old Sun, December 21st, 2008, 10:54 AM
RGSMDNR RGSMDNR is offline
RGSMDNR is on a distinguished road
voltage drop, Gryphon resetting?
I live in Canada and its been around -20 for a few days now. Ive noticed that when i start my truck, the Gryphon thinks it just got plugged in and displays the HEX file... is this anything to be concerned about? Should i unplug the programmer until it warms up a bit?
Old Sun, December 21st, 2008, 02:50 PM
jfuller5 jfuller5 is offline
Location: Upstate New York , Cambridge . lake george area
jfuller5 will become famous soon enough
Default battery voltage
I would also check the pin connectors at the OBDII connection and make sure they grip the plug on the Gryphon connector very well. When temps drop connectors contract and sometimes will make poor connections, then as temp rises the connection is remade as the connector expands. This isnt uncommon in some connectionns in cars. The material used in electrical connectors can move quite a bit with temperature changes. Worth a check, Jim
Old Sun, December 21st, 2008, 08:12 PM
That's fantastic advice! These are things you don't think about when you live this far south.
Old Mon, December 22nd, 2008, 09:45 PM
Northern Supercrew's Avatar
Northern Supercrew Northern Supercrew is offline
working for parts.....
Northern Supercrew is on a distinguished road
Almost killed my battery couple days ago...-43 and not being plugged in will do that. plugged the charger onto it and got it fired up. The Gryphon screen would not display until truck warmed up. Thought to myself....weak battery=tunes lost.:weeping: when truck warmed up, went into menu and seen they were still there This little box is tough.
2008 f150 supercrew, 5.4, 3.73 LSD, tonneau cover, 275-65-18 BFG's. Gryphon programmer. XLT with XTR package. Tinted heads and tails with 8000 HID's. 4300 in the fogs. Gott's Mod. Painted grill.
Old Wed, December 24th, 2008, 09:21 AM
Its been a little warmer around here so i havent had the issue. Ive got the truck in the dealer right now because the 4wd doesnt operate properly. Ill keep and eye on the battery, the truck is only a year old so it should be ok...
thanks all!!!
Old Wed, December 24th, 2008, 09:57 AM
One thing I DO know, Northern, is that a weak or dead battery will not destroy your tunes, either what's loaded in the PCM or in the programmable memory of the Gryphon.
Consider: you can take the Gryphon out of the vehicle for extended periods (which is equivalent to having no battery) and, you can take the battery out of the truck with the same results (although the PCM has to relearn its idle strategy and maybe a couple of other things I think after an extended period with no "keep alive" power).
The technology in both the Gryphon and the PCM is similar (maybe the same) as what you see in USB "thumb drives". Now, if you were to zap any of these with high voltage, all bets are off.
Old Wed, December 24th, 2008, 03:50 PM
I wouldn't use it as a wheel chock either!
You are correct, Jack. Both the PCM and the Gryphon (as well as pretty much any other programmer on the market) use what is call "Flash" memory. This is the same stuff you find in thumb drives, digital cameras, and about a zillion other things.
Here's a quick rundown of Flash Memory:
Flash memory is really cool because it is BIG on storage, has a very small footprint (a 8GB Micro-SD is about the size of your pinkie nail), and is CHEAP to produce. It is non-volatile which means that unlike RAM (high speed memory used in most PCs), it doesn't need power to store the data. The data gets "burned" onto the storage grid. When you need to make a change, you can then "Flash" it to erase it and re-write it. It also has a LONG retention rate (on the order of years).
The drawbacks are it is SLOW (compare to RAM, anyway) and you can't erase and re-write 1 byte at a time. You have to erase the memory in blocks (4K, 8K, 64K, etc) which means you have to be able to copy a whole block of data elsewhere, erase the block, and write it back with the change included. Having to read and write 65,536 bytes to make 1 change is not fast. This is why 1 GB of RAM is roughly 50 times the size (footprint) of 1GB of Flash.
So as I said, most (if not all) programmers as well as all re-flashable use Flash Memory because of the reliability of the data retention. Remove the unit? No problem. Batter is dead? No problem.
I will mention that because of the way the data is written in Flash memory, this is why we DO NOT RECOMMEND programming in cold weather. If the flash temp is below spec, the data may not write correctly resulting in data errors.
See? Learned something new today!
Old Wed, January 7th, 2009, 10:04 AM
Dixie Design's Avatar
Dixie Design Dixie Design is offline
Warranty Voider
Dixie Design is on a distinguished road
Just a side note, if ya'll are replacing your batteries, might not hurt when you purchase a new one to get one with more Cold Cranking Amps. That's probably all they sell up in Canada, lol. Was actually really difficult for me to find one with extra cold cranking amps down here in South Georgia!
Specs: 2004 4.6L SCAB | Gryphon Programmer 87 Performance | Magnaflow True Dual Exhaust - Rear Cat Delete | S&B CAI | Summit Underdrive Pulleys | Troyer eFans (ordered) | Smittybilt Bullbar | Procomp 6" Driving Lights | UWS Toolbox | Rhino Lining | Chrome Steprails | 2.5" Leveling Kit | 265/70/R17 Goodyear Wrangler AT's
Vids: Magnaflow Startup & Revs - Interior Exhaust Sounds
Old Wed, January 7th, 2009, 07:27 PM
OneTomcat's Avatar
PHP Cheerleading Section
If the Gryphon shuts off and comes back on (with hex code showing) while running at highway speeds, is that an indication of weak battery as well, or do I have other issues?
'05 F150 FX4 SCAB
K&N FIPK
Magellan Navigation System
4UCam wireless backup cam
Old Wed, January 7th, 2009, 08:11 PM
This sounds to me like a power interruption to the Gryphon. Maybe you have poor connections at the OBDII port or in the cable where it plugs into the Gryphon. Have you checked that these are both secure? Maybe you could kind of unplug and replug both connectors with the power off to "burnish" the contacts and then, before plugging the cable back into the OBDII port, turn the ignition ON so that the unit will reinitialize properly?
I'm assuming here that your alternator and battery are both good. What do you see on the Gryphon when you monitor charging voltage? I see something in the neighborhood of 14.1 volts when driving during the day and not towing my trailer with its two additional batteries (that drag the voltage down).
