Old Thu, June 4th, 2009, 05:57 PM
87ttopstang 87ttopstang is offline
87ttopstang is on a distinguished road
Default Using in two trucks???
I have a buddy who is going on a long trip and he wants to know if he can use my Gryphon on his trip. If I reprogram my truck to stock and remove the programmer, will he be able to use it on his? Same truck, exact same mods, same year.
After he is done, return his to stock, then put back in mine and reprogram mine?
Is this possible or is the programmer married to one vehicle once it is used?
Thanks.
Old Thu, June 4th, 2009, 06:00 PM
IF, you have only canned tunes, the Gryphon should program his truck to any of those canned tunes. And, IF he reprograms his to stock after the trip it should work again on yours.
If you have custom tunes, it will not work unless his PCM has exactly the same HEX code, which is not likely.
