Old Sat, June 13th, 2009, 04:14 PM
king0581 king0581 is offline
king0581 is on a distinguished road
Default Questions on 6 position chip
Hello folks, just joined up here and see some familiar folks. Been thinking about finally pulling the trigger on something that I don't have to wait forever to change programs, not that I change that much. I mainly run it in the race setting on my Edge, unless I'm towing then I just return to stock because I don't see much difference in the tow setting from stock.
I thought about just reprogramming the Edge but would rather have something shift on the fly.
I was searching over the different tuners out there and these have the best price I've seen. I was looking at the 6 position chip and was wondering about the options. I have a 6 speed and was wondering if the tow programs would help me at all or should I just go with the performance settings? From what I am seeing its not recommended to go over the 100hp setting with my PMR's. Is this correct? I don't tow heavy often but I do move equipment (tractors and such) every so often. I do tow my bass boat as often as possible.
I also have a sticker under the hood that says the PCM was reprogrammed and it gives a number, if that makes a difference. I even went out today and pulled the PCM to get the code because it was no way I was going to see it by pulling the harness plug off.
I was looking to get a high idle, and a stock setting, so I got a few more positions to fill. I don't need the Valet or teen driver settings, because I'm the ONLY one that drives my truck. Also how much difference is there from the fuel sipper setting to the daily driver? Any help on this or recommendations on what I should get would appreciated. Thanks for the help and sorry for the long first post.
Lee '03 F250 4x4 with the 7.3 and 6 speed. Ford AIS air filter, zoodad mod, 4" MBRP st stl exhaust, wicked wheel, shimmed FPR, hutch and harpoon mods with prepump filter, CCV mod, cold AC mod, leveling kit wit 305's and a few shiney extras!
Old Sat, June 13th, 2009, 11:31 PM
Originally Posted by king0581 View Post
Hello folks, just joined up here and see some familiar folks. Been thinking about finally pulling the trigger on something that I don't have to wait forever to change programs, not that I change that much. I mainly run it in the race setting on my Edge, unless I'm towing then I just return to stock because I don't see much difference in the tow setting from stock.That's normal because it's designed for a first modification and for folks not interested in a pyrometer.
I was searching over the different tuners out there and these have the best price I've seen. I was looking at the 6 position chip and was wondering about the options. I have a 6 speed and was wondering if the tow programs would help me at all or should I just go with the performance settings? As far as a manual transmission-equipped truck goes, you will find very little difference in the power delivery from the tow programs to the performance programs. USUALLY, the tow programs are designed to get the most from the automatic transmission trucks because that's where the programming really shines.From what I am seeing its not recommended to go over the 100hp setting with my PMR's. Is this correct? You really can't make or use more than that without mechanical upgrades anyway and stock injectors are pretty "safe" as it is. I don't tow heavy often but I do move equipment (tractors and such) every so often. I do tow my bass boat as often as possible.
I was looking to get a high idle, and a stock setting, so I got a few more positions to fill. I don't need the Valet or teen driver settings, because I'm the ONLY one that drives my truck. Also how much difference is there from the fuel sipper setting to the daily driver? Daily driver is going to be responsive, add a few ponies, and make your truck a pleasure to drive; not be such a chore anymore. Fuel sipper changes a few low boost fuel maps, ICP maps, and start of injection timing maps to help eliminate smoking off idle. It's a little less "fun" than the others, but adds a nice bit of power once you stand on it.Any help on this or recommendations on what I should get would appreciated. Thanks for the help and sorry for the long first post.
See replies in bold.
The first thing you'll notice going from the Edge Evolution to one of Bill's custom tunes is the "normal" feeling of the accelerator pedal....the uncomfortable "touchyness" will be gone. I know you know what that feels like with the Edge....the throttle becomes less of an on-off switch with the custom tunes.
Old Sun, June 14th, 2009, 12:28 PM
get the smoke show... its fun you will get pretty good smoke on the second half of the throttle on the 100hp and up tunes. Im in LA at the moment and running the 100HP. I am getting new tires on Tuesday so I gotta redo my tunes then to adjust speedometer settings.
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Old Mon, June 15th, 2009, 05:40 PM
That will be great if it takes out the touchyness of the pedal. So this is what I'm thinking of going with...
Stock
1200 High Idle
Whisper
65 tow or 65 daily driver(for just a lower HP setting for towing my boat)
80 daily driver
100 race (for playing a bit, as much as stock injectors with my mods will allow)
Opinions?
Old Tue, June 16th, 2009, 06:16 AM
I think your list looks pretty good! A few days ago, I updated our calibration list (and the Phoenix Order Form) found below; I just wanted to make sure you have all the information available before making any final decisions. And though it's our phone closure week, if you need to run anything past Bill, please feel free to shoot me an e-mail with your phone number, and Bill can give you a call after 6PM to chat a bit.
STANDARD CALIBRATIONS
  • Daily Driver calibrations have timing and fuel curves set up to maximize efficiency and improve overall driving experience
  • Performance calibrations have a slightly more aggressive fuel and timing curve than our Daily Driver calibrations; good choice for drivers with a heavier foot
  • Tow calibrations use shift strategies designed to maximize towing capabilities
  • Race calibrations are designed to increase your vehicle's horsepower and have more aggressive shift points
  • Extreme calibrations are designed for the weekend warrior who wants a program to turn his vehicle into a quarter-mile monster! We do not offer a 140HP calibration for trucks with PMRs.
  • Power Calibrations - On diesel vehicles, we offer 25HP, 40HP, 65HP, 80HP, 100HP, 120HP and 140HP levels.
  • Anti-Theft (no charge for this calibration) - Prevents truck from starting; use it when you park your vehicle (Last Level ONLY)
  • Stock Calibration (no charge for this calibration) - Useful for emissions testing or diagnostic purposes; choose Modified Stock Calibration for trucks with heavy mods (we recommend placing this calibration in Level One)
  • Valet Mode - Lowers the speed limiter (20, 30, or 40mph)
  • Teen Driver - Lowers the speed limiter (65 or 75mph)
  • High Idle - Ideal for PTO operation or for faster warm-ups
  • Fuel-Sipper™ - fight rising fuel costs; use for around town stop-and-go traffic -- NOT designed for highway driving
  • Whisper Mode™ - Now you can hit the drive-thru and place your order or do your banking without having to turn your truck off
  • SmokeShow™ - Large quantities of low-boost fueling to provide big clouds of smoke
Thanks. I am still doing some thinking on the 100hp setting......
How much seat of the pants feel would I have between the 100 race and 100 performance? I do have a more aggressive driving style, so I was thinking of going with the 100performance for those days instead of the race. I'd like to be able to play a little bit but I may just drop the whisper setting for a go fast setting.
