Old Mon, June 15th, 2009, 11:10 PM
jac443221 jac443221 is offline
jac443221 is on a distinguished road
Unable to download custom tunes
So I got the email the other day that my custom tunes were ready. I updated pegasus, programmed truck back to zero, Then followed the steps to download tunes.
This is the error msg I received on the screen word-for-word:
"Unable to locate a valid Target Instruction file.
This often occurs during server maintenance or when files on the server are being updated.
This is may also be caused by a firewall issue or other internet related problem.
Please contact Power Hungry for further assistance."
Then, I clicked "OK" and it gave me this text in the Pegasus screen:
"Unable to locate a Target Instruction file. Process failed
Update failed. Please contact your vendor for assistance."
I then disabled my firewall and tried again and same thing. I read another thread where someone had the same issue and Bill mentioned the tunes not uploading on the server. Any help would be appreciated
Old Mon, June 15th, 2009, 11:31 PM
You will need Bill's help.
Old Tue, June 16th, 2009, 09:37 AM
Sounds good. Thanks
Old Tue, June 16th, 2009, 11:12 AM
bart_r6 bart_r6 is offline
07 F150
bart_r6 is on a distinguished road
I have the same exact issue. I tried a few times but no luck.
I'll need Bills help also.
Thanks, BART
Old Tue, June 16th, 2009, 11:21 AM
Thanks, BART
Bart, you're going to have to be more helpful. Please go to the UserCP and enter all your personal information: full name, programmer serial number, model number, hex code, etc.
Then, download and install Pegasus, click on Help->Registration and fill in all the details there too. That way PHP's server will be able to "talk" to you.
Old Tue, June 16th, 2009, 11:46 AM
07 F150
Thank you. I just finished updating the pegasus...it work ok now.
What do i have to do now to upload the custom tunes from the e-mail to the gryphon? Thanks
Old Tue, June 16th, 2009, 11:58 AM
tg150 tg150 is offline
tg150 is on a distinguished road
Using Pegasus to update your hardware.
In order to update your Gryphon, the first thing you need to do is make sure that you have installed the Pegasus Update Client. Here is the download link:
http://www.powerhungryperformance.co...v2_01_0575.exe
You may also want to download the Quick Start Guide at:
http://www.powerhungryperformance.co...user_guide.pdf
Once installed, run the Pegasus application. Always make sure you have the latest software version by going to [Updates] and then [Pegasus Update Manager]. If there are any updates available, you will be notified. If not, then continue on.
To update your Gryphon with CUSTOM files, follow these simple steps:
Make ABSOLUTELY SURE you return the vehicle back to stock before going any further. In most cases an update shouldn't be allowed unless the programmer is back to stock, but some early versions had a firmware bug that may cause the all the data on the unit to be lost when trying to update while still programmed.
Connect the programmer to the USB cable.
From the main Pegasus screen, select [Updates] and then [Targeted Functions] to begin the custom download.
Follow any on-screen prompts to disconnect/reconnect the USB cable. Later versions don't usually do this, but early versions do. Make sure to read all messages before clicking [OK].
Once the update is complete, you may remove the USB cable and return the unit to your vehicle..
2004 Scab Lariat
Leveling Kit, 20"OEM's, Magnaflow SI/DO Exhaust, AirAid Jr Intake Kit, K&N Drop in, PHP Gryphon.
Old Tue, June 16th, 2009, 12:28 PM
Nice instructions tg150!
I will just add in to make sure the drivers install. That's done it to me a couple of times on vista 32.
Old Tue, June 16th, 2009, 12:46 PM
Very good, tg150! You're getting almost as "long-winded" as me! Trying to put me out of a job?
Excellent post! I'll add though, make sure your ignition key is ON before you plug the Gryphon back into the OBDII port. (See, I couldn't leave well enough alone, could I?).
Old Tue, June 16th, 2009, 12:59 PM
Jack, Your a riot..I certainly dont qualify for your job so no worries there Besides.. You and Lars do an excellent job. Just noticed you both weren't online and thought id help the one time that i can actaully contribute instead of askin q's .
2004 Scab Lariat
