Old Thu, July 9th, 2009, 10:36 AM
PZX_2002 PZX_2002 is offline
PZX_2002 is on a distinguished road
Default Custom settings for the 87 canned tune?
I found this information for the 91 canned tune thanks to BlueJay:
"On level 3, be sure to bump the timing up if you run higher than 91 octane. I ran 93, so I bumped mine up +1.25. Go up at least .5 for each octane."
shift pressure= +12, +12, +9
WOT shift points= 5250, 5250, 4800
Max RPMs= 5650
WOT Fuel= + 1.60
Speed limiter= 110
Be sure to set you gears and tires correctly.
Now my question is, is there a custom setting for the 87 canned tune?
Also to configure the step above I go into the menu, then select a "custom" option, and then what?
thanks fellas....................
Old Thu, July 9th, 2009, 11:11 AM
Question
Which 87 generic tune are you looking at modifying?
The 87 oct tranny(level 1) only or the 87 oct tow(level 2)?
When doing custom options follow this link:
http://dygytalworld.ehost-services13...=9248#post9248
If you are going to do anything run the level 3 then do the adjustments with BJ's settings but make sure you are running the right octane for the tune!
Old Thu, July 9th, 2009, 11:13 AM
wondering about the 87 octane tow level 2 canned tune.
