Old Wed, July 29th, 2009, 04:15 PM
Brutis Brutis is offline
Brutis is on a distinguished road
Default Chip Problems
Hi Everyone,
I just installed my Phoenix chip. I have noticed some intermittent problems. In the moring the truck doesn't seem to want to start on one of the tune settings. I switch it to stock and it starts and then switch it back to a tune and all is well. I drive it during the day and shut it off and once in awhile it won't start on the tune. On at least one occasion it wouldn't start at all until I pulled the chip and re-seated it. I have the chip plugged in solid with duct tape across the end of the chip and down each side.
My first thought was that the pins on the PCM were not clean enough. I have pulled it again and checked the pins and they are clean. I don't want to work with them any more for fear of taking them down too far. I have worked with edge connectors for years as I am an IT person (for a living).
Any thoughts?
Thanks,
Jerry
Old Wed, July 29th, 2009, 06:33 PM
I have sent a message to Corey so she can query the "mad doctor".
Old Wed, July 29th, 2009, 07:03 PM
Default Thanks!
Cody,
Thanks, I appreciate it.
Jerry Hart
Old Wed, July 29th, 2009, 08:09 PM
Jerry,
Let me know if the problem continues after the "reseating of the chip". If so then it's possible that there is a problem with the chip.
Just to let you know, we've just recently been notified by TS of a component change on the chips that is supposed to resolve an issue that is very similar to what you describe. If the problem persists then let us know and we'll be happy to replace the chip for you. The "modified" chips should be in sometime next week.
Old Wed, July 29th, 2009, 08:38 PM
Thanks Bill!
I have already taken the chip out once, re-cleaned the terminals and reseated the chip.
I am going to drive it tomorrow and see if I run into the same issues. I will let you know.
Thanks for the response!
Jerry
2000 F250 SD SC XLT 4x4 auto 142k - Tymer intake, PHP Tunes, MBRP 4" Turbo back, Autometer guages, HX, Tymer Coolant Filter, WW, Foil Delete, CCV, Wet Okole seat covers, Custom grill.
Old Wed, July 29th, 2009, 10:34 PM
They probably put a level shifter on them since the CPLD is a 5V unit and the flash memory is 3.3V.
