Old Fri, August 7th, 2009, 09:39 AM
ean's Avatar
ean ean is offline
ean
ean is on a distinguished road
Question gryphon ?
I noticed since I installed my gryphon that when I am driving and my rpm's hit 2000 rpm my CAI makes a loud growling sound but when I put settings back to stock the growling goes away is this normal. I have a Spectre COA with the baffle in it for the mass air sensor itkind of sounds like it needs to come out when i run my can tunes. Has this happened to anyone please let me know how I can take care of this annoyed
Ean
Old Fri, August 7th, 2009, 10:05 AM
Ean
Ean, I don't know the year and model of your truck, but the 04-05 MYs came from the factory tuned pretty lean and adding some brands of CAIs made that condition worse. Some seem to be noisy with the canned tunes. Bill will take care of BOTH conditions when he writes your custom tunes.
In the meantime, if you're going to run a tune, use Level 2 (it's a bit richer) and try to keep your foot out of it.
And, to help Bill help you, would you fill out all the info in your UserCP? (Full name, unit serial number, Hex code, etc.).
Old Fri, August 7th, 2009, 10:18 AM
p40whk's Avatar
p40whk p40whk is offline
p40whk is on a distinguished road
I have a CAI (AFE or AEM, can't remember which) and it growled like that a lot more at the stock setting than it does now that I'm running the 87 tow (level 2) canned tune. That along with the shift point changes has made the truck more drivable. I can't wait till I get my custom tunes! Hopefully that growl will go away or at least be a lot quieter and I can actually take advantage of the performance that the CAI is supposed to provide. I'm already happy with what level 2 has done.
Old Fri, August 7th, 2009, 12:17 PM
MyMuddyTruck MyMuddyTruck is offline
MyMuddyTruck is on a distinguished road
I have a Volant cai on my 07. Without the programmer, it has a nice rumble sound and it gave me a good mpg increase, but as soon as I hooked up the programmer with canned towing, I got a loud annoying drone between 1800-2500 rpms so I removed it. I was told that the custom tunes might fix the problem. When I did get my custom tunes, the drone is still there so I can't even use my cai because it is so loud and annoying. I love what the custom tunes have done for my truck but now I can't use my cai.
Old Fri, August 7th, 2009, 01:15 PM
ean's Avatar
ean ean is offline
ean
I do nt have the custom tune yet but i am hoping that once i get it that growling will stop
Old Fri, August 7th, 2009, 09:44 PM
lbjailer's Avatar
lbjailer lbjailer is offline
08F150LARIET
lbjailer is on a distinguished road
I installed my K&N CAI and it doesn't growl until the RPM are above 3000, even before the custom tunes, but it sure makes a big difference. I installed it while waiting for my Evo upgrade to arrive. Really makes the truck sound "mean" when you floor it. It even drown out the exhaust noise its so loud, but only when hot dogging. Supposed to make 15HP and something like 8lbs of torque, but I like the sound.
