Old Sun, August 23rd, 2009, 08:30 AM
aaron ford aaron ford is offline
aaron ford is on a distinguished road
Default Ideas for Tunage
Okay guys I have a question. Could a tune be written to reduce the white smoke on cold startup? (It is an old truck and some of it's issues are developing issues of their own, but it's my toy.) The reason I ask this is that one morning I forgot to plug in my ICP after doing some other repair. To my amazement, the truck did not smoke at all. Not sure why and I have not tried to repeat it, but could a file be written so that idle is picked up and fuel is turned down?
A second thought I had is what about an 7 speed file? 1st, 1st lock, 2nd, 2nd lock, 3rd, 3rd lock, OD. Properly done this would keep the engine right in the sweet spot. Or would it?
Just thinking out loud,
Aaron
Old Sun, August 23rd, 2009, 09:55 AM
I'm going to sit here for a while and decide how I want to write out a response to these two questions. I just woke up and my mind isn't exactly sharp just yet but I have great ideas running through my head.
Stay tuned.
Old Sun, August 23rd, 2009, 08:51 PM
Since Cody hasn't apparently "sharpened up" yet... ... I'll give this a stab.
First, it's very easy to eliminate much of the cold-start smoke associated with older trucks. A mild increase in ICP and an additional 1-2 degrees of timing in the colder oil temps will usually clear that nonsense right up, especially the timing although, as you've seen, ICP can certainly help that issue out as well.
In regards to the shifting, what you described would be an ideal setup. The problem is that it's not terribly feasible because the transmission would be shifting in and out of gears and locking/unlocking the converter every time you so much as breathe on the throttle.
Years ago I worked on a calibration set that took all the converter lock functions out of the equation, making it basically a 4 speed, open converter transmission. I got the shift points lined up where I thought the felt good (having to overshoot a little considering where I'd intended to be bringing in the converter lockup) and then brought the converter strategies back in. I will tell you, it shifted like crap. With the converter unlocking between each gear it, would cause all sorts of crazy RPM fluctuations that just didn't feel right. It always had that feeling of not knowing what gear it wanted to be in.
Believe it or not, Ford actually did something that was not too far off from ideal with their '01 strategies. At light throttle, the converter doesn't lock until 3rd or 4th gear depending on how much throttle you're giving. At heavy throttle, the converter will lock in 2nd and stay locked through 4th in order to provide more direct power to the transmission and reduce heat buildup and ballooning of the converter. This is actually one of the more ideal setups. Later strategies ended up busying up the transmission and really made the shifting horrible.
Shifting is always a hard function to get nailed down because of the number of factors to take into consideration, including customer preferences. We do the best that we can but sometimes you just have to accept the limitations and settle for some middle ground.
Old Sun, August 23rd, 2009, 10:23 PM
I have a good excuse for not replying earlier .
The torque converter used in the Powerstroke is designed simply to "save the transmission". In other words, it has a high stall speed and a very low torque multiplication factor. This allows the engine RPM to rise very high in relation to the actual input shaft speed. If you factor in the transmission gear ratios (which are absolutely stupid and useless in a 4-speed automatic) of 1st (2.71:1), 2nd (1.54:1), and 3rd (1:1), then it becomes apparent that the act of going from 1st locked to 2nd unlocked will actually cause an INCREASE of engine RPM during a shift....and a shift that causes a near absolute loss of drive wheel torque. The same would happen (and even moreso) during a 2nd locked to 3rd unlocked transition. The limited and closely spaced gear ratios in the E4OD and 4R100 make this a very undesirable mode of operation and once the torque converter is locked, it makes sense to keep it there.
The biggest problem I have noticed, especially when using the stock PMT2 calibration that my truck came with, is that the torque converter unlocks for a full 2.5-3 seconds during a 4-3 downshift while under load either forced or after a TCS (OD off button) push. It's ridiculous how much rear wheel torque is lost during this short time....and it's extremely annoying. The problem is compounded by an instant jump to 3200 RPM at 73 MPH....if you look at a dyno graph for a 7.3L, you'll see that 3200 RPM is useless. Good thing there are ways around it with different PCM codes and programming techniques.
I would be VERY hard to get the shift timing right while attempting to tune what you are describing. This is mostly due to the variable shift points that are encountered depending on acceleration rate and different accelerator pedal positions.
On the white smoke issue, my thoughts are that of Bill's. I would also assume that it is due to the slightly higher commanded injection pressure combined with the added cold start of injection that cleared up the white smoke. I will also point out that white smoke on startup can also be caused by low compression or an inoperative glow plug or two. But since it didn't smoke when the ICP sensor was unplugged, I don't think I'd blame any mechanical issues. The PCM will default to 725 (calculated by Injection Pressure Regulator duty cycle) at idle when the ICP sensor is unplugged. This is a bit higher than the 485 or so PSI that is commanded when the ICP sensor is functional.
Old Sun, August 23rd, 2009, 10:35 PM
Yeah, yeah, yeah...
Old Sun, August 23rd, 2009, 10:42 PM
Seriously. I was dismantling a '91 E-350 van for a donor engine, transmission, and wiring harness. I'll tell you now that pulling an engine and transmission out of a van in one piece is a mutha!
It's a 460 and E4OD for my '73 F-100. Turbo project? Probably.
I'll probably need an MDF for that one too.
Old Sun, August 23rd, 2009, 10:55 PM
Sound like fun! Allow me to tell you a funny story and give you an indication of my relationship with Corey.
When Corey and I were first dating, I was still working as a mechanic in an independent shop. We had a van in the shop that I was working on that we did an engine rebuild on (351M, if you're curious) and had to have it running the next day for a customer. Well, at about 6:30 pm Corey came over and sat with me while I started putting the engine back into the van. As you know, vans aren't any fun to begin with but it was really cool having her there with me. In no time at all, I had everything bolted back in and fired up. (No time being a relative term... it was actually about 5 hours.)
Even back then, Corey was happy to be around me and ask questions and take an interest in what I do. The only difference today is that I don't need 2 bars of soap and a pint of GoJo before I can give her a hug.
Just thought you might find that amusing.
Old Sun, August 23rd, 2009, 10:57 PM
For a warm and fuzzy feeling......
I have felt/feel the same way about my significant other.
I just need a "clean" job now.
Old Sun, August 23rd, 2009, 11:04 PM
If you ever decide to trade MT for GA we might be able to help.
Old Sun, August 23rd, 2009, 11:24 PM
Thanks for the replies, guys. I suspected that there was some reason for not having a progressive shifting tune.
I hate my stock TDE1 shift pattern. I am hoping the 65P tune or the 65tow will allieve my issues. It does odd things like upshift under a throttle increase at 2200. On a full power pull, when the TC locks in second, the third shift is only moments away. The two events drop the engine below 1500 and out of any available power. For some reason, it shifts better cold.
My throttle acts like an on-off switch which may have to do with the 15K resistor in the ICP harness. This resister willl be long gone before installing the Phoenix. That is why it was never mentioned.
Thanks,
Aaron
PS, Dry laundry detergent is cheaper than gojo. Just wet hands, pat both sides in the detergent, wash as usual. Hope you don't have any cuts on your hands cause it'll send ya to the moon. The only van experience I had was pulling a 351w and the van was going to the scrapyard. That dash was trashed!
