Old Wed, September 2nd, 2009, 04:13 PM
mkf350 mkf350 is offline
mkf350 is on a distinguished road
Default Where did YOU mount your 6 pos switch???
Just curious where everyone has mounted there 6 position switch, hopefully with pics but not necessary..
2002 F-250 CrewCab LB
AFE ProGuard 7 intake
4" Magnaflow ss exhaust with 4" downpipe
BTS Trans Valvebody
Dieselsite Adreneline HPOP
Garret GP38R turbo
PHP Phoenix FU
Old Wed, September 2nd, 2009, 04:28 PM
I put mine on the left side of the steering wheel centered under the headlight switch. It is very low profile and that is what I wanted.
I had to take the fuse block off it's mounts to run the switch wire and mount it back up when I was done but it was not that much work and I think it was worth it.
I will try to send a picture later
Joe
Old Wed, September 2nd, 2009, 04:54 PM
Peroni's Avatar
Peroni Peroni is offline
Hit n Miss
Peroni is on a distinguished road
I put mine here, very easy to reach and change w/o having to look away from the road.
the 1997 F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, electric fuel, CCV mod, tru-cool 4739, Swamps 175/30% injectors, stage I Stealth pump, D66 turbo Spearco 6.0 cac, BDP live tuned tuned 442hp/860tq.
Old Wed, September 2nd, 2009, 07:00 PM
Big Bird Big Bird is offline
Big Bird is on a distinguished road
mine is hanging from the trailer brake controler, havn't gotten around to drilling the hole in the dash yet. Give me some time, it only took me 1 1/2 years to finally install my gauges in the truck...
Old Sun, September 6th, 2009, 10:08 PM
Orezona Orezona is offline
Orezona is on a distinguished road
Can't tell you. It is in stealth mode
Old Fri, December 18th, 2009, 06:10 PM
majek5's Avatar
majek5 majek5 is offline
Nothin' Stock
Between the headlight switch and the front/rear tank switch. Fits like a glove, and if you weren't lookin you would not see it.
Old Fri, December 18th, 2009, 11:15 PM
dang, yours must be smaller than mine...
I don't think mine would fit there.
Old Mon, December 28th, 2009, 11:47 PM
sam8 sam8 is offline
sam8 is on a distinguished road
Mine is down low in the lower panel to the left of the steering wheel, I just used the hole from my old 3-step chip form Bill way-back-when.
I am going to move it though. This is giving me some good ideas.
Proud father of a U.S. Army veteran, proud uncle of an Active Duty U.S. Army Ranger.
'97 F-350 CC LB 4x4-Orignal Owner. Arrowcraft DRW Kit, Tymar int., Banks IC, Beans D-66 Turbo, Hypermax DP, 4 inch exhaust, ATS Triple Loc converter, Mag Hytec Trans Pan,Tru-cool Trans Cooler, ORU Shackle Reverse, Ultralite Gauges, PHP F.U. 2 Flex 6 pos. chip Terminator modded 17* HPOP and Scan Gauge
Old Fri, January 1st, 2010, 04:17 AM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
OBS FTW.
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Fri, January 1st, 2010, 05:12 AM
I like that, Chuck. Very nice!
