Old Sat, October 31st, 2009, 02:19 AM
outosite outosite is offline
outosite is on a distinguished road
Question Phoenix 6 Pos. Chip Questions
Rig: 2001, Ford F250 Crew Cab, 7.3 PSD, Auto, 4x4, 3.73, 125K.
Mods: Stock + Stage II CAI, 4” MBRP Turbo Back.
Use: Daily Driver, Work, Tow and Play
Looking at the following tunes, but open to suggestions:
Stock
High Idle - 1,100rpm
40hp Heavy Tow
65hp Daily Driver
80hp Performance
120hp Race
Questions:
What tune offers the best average daily in-town & highway full economy when running empty? When towing <10k?
Can Lope Idle be combined with say 120 Race?
In this way, when running 120 Race setting at the light idling, it would be Loping until I nailed the fuel.
Any negative impact to doing this?
When in High Idle, does it remain drivable? (I understand that the Auto Tranny will pull if in gear, but in my case, this is desirable)
Can High Idle be combined with say 40hp Heavy Tow?
Do you offer a High Idle that also closes the EBPV, for faster cold warm-ups?
If yes, does it follow the factory time delay before closing the EBPV and idling up to protect the cold engine?
At what HP tune level should I become concerned with shortened longevity of the engine and tranny under continued use?
Are the factory TC Lock/Unlock routines maintained?
At what HP tune level do I become concerned about additional modifications, say head studs, HP Oil, Fuel Filters, Rods, etc.?
Less directly related:
Looking to future, for highway economy, and street level performance, which is a better upgrade, Propane or Water/Meth? I tend to think Propane is the best overall solution, base on its history being used on Semi-Trucks. I am really looking at these two options as a way to increase fuel economy through better fuel usage.
Looking to future, may also start running a B20 blend. Any changes or consequences to doing this without additional rig mods? Different tunes required?
I read though forum, but could not find answers that seemed to fit my questions.
I originally e-mailed these questions some time ago, but having not heard back, thought I would give the forum a try.
Thanks for your time to respond, I’m sure it is in short supply.
Old Sat, October 31st, 2009, 09:52 PM
Well I am not good at doing the color coded responses that Cody does but Ill answer some
See the Minotaur forum as we recently were talking about a cold weather tune. there is lots of good info in that forum if you want more technical info
Not sure about the delay on closing the EBPV. The high idle can be put on any tune. it just changes the base engine speed value to whatever you want and yes it will start to pull in gear at hi idle. a bit more info on why you would want to drive with high idle would be helpful. I have mine at 1200 cuz that is what my alternator produces max amps at.
as for fuel economy I have not noticed a big difference in varied driving with and with out towing. go to Fuelly.com and look for my Ex... same user name to see my MPG history.
The Fuel sipper is really for in town driving with lowered shift points to keep RPM's down you would not want to tow with that tune.... the 100 and 80 HP performance tunes are my daily drivers
I just got the 25 and 40HP tow tunes from Bill but havent tried them yet...
With good tunes matched for your vehicle you will not be shortening the engine, tranny life... its all in how you drive and maintain it.... you may have the mechanical diode as you have a 2001 truck .. late 01's like mine dont have that.....
if you are towing a lot get a Transgo tugger kit installed or a modded Valve Body. The trannys are sort of the achillies heel of the fords
Head studs are not a 7.3 issue. the issue is the Powdered Metal Rods (PMR) vs the forged rods in earlier PSD engine... I have the 140 HP and it runs fine even on the PMR s but I don't use it often. above about 120HP you will start needing additional mods you mentioned and $$ per HP goes up exponentially from there...
there are changes to the TC shift points and Duty cycles etc... us Minotaur users mess with the tranny settings quite a bit.... Cody is the tranny expert around here
You shouldn't need different tunes for commercially made B20....
I recommend running a Full Synthetic engine oil... no idea about the propane meth water thing.. never messed with it
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
Old Sun, November 1st, 2009, 04:13 PM
Use: Daily Driver, Work, Tow and Play So usage is "everything" .
Stock
40hp Heavy Tow
65hp Daily Driver
80hp Performance
120hp Race
Questions:
What tune offers the best average daily in-town & highway full economy when running empty? When towing <10k? Depends on your right foot. Optimizing operating characteristics by way of aftermarket tuning always helps a little as long as you can control your right foot. The 65 and 80 HP tunes will probably be your best bet for steady-state driving (like interstate or highway cruising).
Any negative impact to doing this?I would assume so....however I think the transition between the lope idle and regular operation may be a little hard on the engine. That's a question for Bill. I wouldn't do it in my tuning.
When in High Idle, does it remain drivable? (I understand that the Auto Tranny will pull if in gear, but in my case, this is desirable) It should be...just that you'll be awful hard on the brakes.
Can High Idle be combined with say 40hp Heavy Tow? Like DJ said, high idle can be implemented in any tune. It's a simple procedure. However, it's up to Bill whether or not he'll do it.
If yes, does it follow the factory time delay before closing the EBPV and idling up to protect the cold engine? The EBPV should already close by itself once the idle increases automatically. I suppose it is reliant on the base PCM program, but you're probably dealing with a VRAA6 or VRAA7 hex code anyway and it SHOULD do that by itself. Otherwise, yes, it is very possible for Bill to program the chip for your desired operation. The time delay can also be changed very easily if you want it to idle up earlier in the warm-up cycle instead of waiting 2 minutes.
At what HP tune level should I become concerned with shortened longevity of the engine and tranny under continued use? It all depends on how you drive it. You could run a 120 HP program all of your truck's life and never have a problem. On the other hand, a 40 HP tow program could kill everything in short order if you drive your truck like a rental car.
Are the factory TC Lock/Unlock routines maintained? They can be but there are changes available for the better.
At what HP tune level do I become concerned about additional modifications, say head studs, HP Oil, Fuel Filters, Rods, etc.? Anything above stock.......if you are looking for more than a "do everything well" kind of truck. For what can be had with stock AD injectors like your truck has, you really don't need any of that. A higher-capacity HPOP is always a welcome addition to any truck.
Looking to future, for highway economy, and street level performance, which is a better upgrade, Propane or Water/Meth? I tend to think Propane is the best overall solution, base on its history being used on Semi-Trucks. I am really looking at these two options as a way to increase fuel economy through better fuel usage. If you're looking at propane for a power-booster, then forget about it now. Any amount of propane that increases power much (if any) in the Powerstrokes (especially with powdered metal rods) is going to kill it quickly. Water/methanol is your best bet.
Looking to future, may also start running a B20 blend. Any changes or consequences to doing this without additional rig mods? Different tunes required? Commercial B20 shouldn't need any changes.
What? Time in short supply? Nah, I finished my honey-do list earlier today.
