Old Wed, January 7th, 2009, 11:07 AM
Question A Question for Bill
Sorry Bill, I know you're busy, but something I saw in one of your posts on another forum makes me curious.
Are the tuning files you create checked for errors after being loaded into the Gryphon? This is something that would/could be done by Pegasus, I think.
I believe it was a fueling map for a diesel engine that had weird spikes in it that got me thinking about this potential problem.
Old Wed, January 7th, 2009, 01:28 PM
And, to clarify my original post, I'm not concerned about errors in the files created by PHP. While we're all human and CAN make mistakes, I have full confidence in Bill's skill and care when he develops his tunes.
What DOES cause at least mild concern are possible errors induced by either the download process from the server to Pegasus in our PCs, or, another possible source of corruption that could happen as the files were written into the Gryphon.
I know there is some kind of error checking such as LRC or CRC performed during the server download process, so I'm not too concerned with the server download either. But, does Pegasus check to see if the file it is uploading into the Gryphon was actually written correctly?
I seem to recall some kind of "checksum" validating going on in the Gryphon when it finally prepares a file for upload into the PCM (or am I imagining something here)?
Hope I haven't caused any misunderstandings with my question, and thank you Corey, for contributing.
Old Thu, January 8th, 2009, 02:44 AM
We perform a number of validation and safety checks, including checksums for data transfers, in order to make sure that the files we send are not corrupted. About the only place we could possibly have a problem (outside of messing something up in the files as they are being built) is if the tuning software was to become unstable and cause a file to not be saved correctly and we didn't catch it before compiling. However, I think that is a pretty remote possibility.
I know it was brought up in another thread about the possibility of the device not being programmed correctly, but our evidence suggests it was a calibration fault, not a defective or improperly programmed device.
Old Thu, January 8th, 2009, 10:35 AM
Ah, I see - you were being very "diplomatic", as usual. Those were pretty horrendous spikes though!
There was another thread in the f150 forums that is now locked, because the OP just couldn't shut up, that complained about an E85 tune from Troyer that was performing very poorly in his truck. The OP finally said that Mike had sent him new files that cured the problem and that the original files had become corrupted somehow. (At least I think this is what he said - some of what he was saying was not too clear).
So, that post on top of the one Corey has mentioned here that I also read made me wonder just how easy it would be for a file to get altered in some manner sometime before the PCM was finally written. I wasn't losing sleep over it, but was mildly curious. Thanks for answering, Bill.
