Old Mon, November 16th, 2009, 07:05 PM
99coalroller 99coalroller is offline
99coalroller is on a distinguished road
Default Questions about chip and trans shifting
I have an early 99 7.3 auto 4x4 and just had a new tranny built for it this past week with a 6.4 converter and a newer valve body as well as a few other little things. My question is this, my original trans would slide into 3rd gear and this one shifts just like my other one. Im pretty sure this is just because of the stock tuning but it really bothers me the way it shifts from 2-3 and i would like it to be firmer and more precise. Has anyone had this problem and can one of yalls chips fix this? thanks
Old Mon, November 16th, 2009, 09:00 PM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Define newer valve body. And yes tuning can help firm up shifts.
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Tue, November 17th, 2009, 10:35 AM
I think its out of a 2002 model, where my truck is a early 99. so its a stock valve body but its better then what came in my truck.
Old Wed, November 18th, 2009, 12:04 AM
ChuckD's Avatar
First I would suggest a valve body from Gregg Evans. I know there are some other big names out there but to me if a guy that I trust on tranny uses his stuff then I can trust its good stuff. http://www.dirtydogperformance.com/t...r/prod_77.html then get a chip matched up to it. I am not sure if Bill if familiar with Greggs stuff though. I am not a fan of firmer shifts just by programing alone. When a valve body is done, some of the holes are enlarged. So not only is the pressure upped the area is upped also therefor giving you greater holding force.
Chuck
1995 Mustang GT
Old Wed, November 18th, 2009, 08:56 AM
Alright ill check that out, also i was reading that a pcm out of a 99.5 to 02 would be a good upgrade and that they are the best pcms to put chips on. The pmt1 i believe.
Old Wed, November 18th, 2009, 11:15 AM
ChuckD's Avatar
If you get a chip it can be burnt using what ever stratagy was best. IE for OBS trucks the best one was TDE1 but if you had a different computer and ordered a chip, the tuning would be based off the TDE1 programming. Unless your computer is toast save your money.
Chuck
1995 Mustang GT
Old Wed, November 18th, 2009, 02:28 PM
Early 99 would be easily upgraded by putting in a DPC 422 PCM.
Old Thu, November 19th, 2009, 08:16 PM
what year of truck did that code come in?
Old Thu, November 19th, 2009, 10:19 PM
99.5-01 49 state trucks.
