Old Fri, December 11th, 2009, 01:57 PM
Ideal150 Ideal150 is offline
Ideal150 is on a distinguished road
Default Custom Tunes
Just a quick question, kinda of silly but... How do you tell if the custom tunes have been up loaded to the unit?
2.5 HBS Level Kit, Magnaflow SI/DO, PHP Gryphon, AEM BruteForce
Old Fri, December 11th, 2009, 11:42 PM
Is it a new gryphon or an upgraded edge?
A new gryphon has canned tunes.
1 tranny only
2 tow tune
3 93 performance
A gryphon with custom tunes will say.
1 87 oct custom performance
2 87 oct custom tow
3 92 oct custom performance
just some examples.
Old Sat, December 12th, 2009, 02:26 PM
I got a gryphon, but when i originally posted I was still at work and hadnt plugged the unit back into the truck. once plugged back into the truck it said custom! What a difference from the canned tunes!! Thanks!
Old Sat, December 12th, 2009, 03:21 PM
There's also this method:
In the Gryphon's main menu select Diagnostics->Tech Support->Version Info. Ignore the warning you'll see. If your tunes are custom, you should see "0.x.xxxx" in the calibration version where the last 4 x's are usually the same as the serial number. If the tunes are "canned", they'll look like "1.x.xxxx" (the version number will start with a one ("1").
So if your calibration version begins with zero ("0"), you've got custom tunes.
Old Thu, December 17th, 2009, 08:07 AM
Also, the calibration version number on custom tunes is nearly always the same as your invoice number. So 0.4.2169 would mean that the tune should be tied to invoice number 2169. It should also match the unit serial number as well, although some upgrades may not correctly reflect this.
