Old Mon, December 28th, 2009, 02:08 PM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
Default Injector noise
On my way back from Vegas I had it in the "smoke show" tune cruising about 65 mph. I switched it to the 65 tune and the injectors would get louder. At an idle there is no differance. Any reason why it does this?
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Mon, December 28th, 2009, 02:10 PM
Chuck,
The smoke tune has a significantly lower amount of ICP than the regular tunes. This results in quieter operation.
Old Mon, December 28th, 2009, 02:16 PM
ChuckD's Avatar
With the lower ICP why would it have a better SOTP feel over the 65 tune. It picks up and takes off harder and gets to speed quicker, 2 lbs more boost and lower egts than the 65.
Chuck
1995 Mustang GT
Old Thu, December 31st, 2009, 09:36 PM
Lower ICP will extend the burn time of the fuel and provide a little more push in low to mid RPM torque. Higher ICP will improve atomization and cause a faster burn, which at high RPM is great but may result in a loss of power at lower RPMs as the burn will completer faster than the piston can properly align to use it. What can often help when running higher ICP levels is to reduce timing a bit more so that the heat expansion occurs at the proper point for maximum effective pressure on the piston.
