1997 to 2003 F-150
Old Sat, January 17th, 2009, 02:28 AM
jbrew jbrew is offline
jbrew is on a distinguished road
Default Help with lean issue
I'm going to be ordering soon, currently have a lean issue (no codes). Plugs are white, electrode has signs of ware @ 20,000 miles after the last plug change. I don't have a cooling problem. I think it's from my mods.
Should I order a canned set from you and then custom tune from there ? Is that how it works ? What exactly should I order ?
I'm a little worried about the lean issue. - Just went thru everything on the engine in preparation for tuning. Went with Denso (16's) for the plugs this time and replaced the coils along with many other components that were marginally bad.
Needless to say, It's just about ready and decided to go with PHP to get her running right.
Besides, I heard your looking for #500 - If not me, I'll help getting yuh there.
BTW - I can't find a computer code that's suppose to be inside the passenger side door ?
98 (Build- 07/98) 5.4L 4x4.
Windsor built 5.4L, E40D, Transgo kit, 9.75 Rear gear, Brembo rotors, Carquest blue's, Bilstein's, Ported & Polished Intake/TB, Pace setter LTH's, Magnaflow HFC's, Magnaflow 22X4 HF Mufler, Type 3 19lb Injectors, Volant Intake w/WIX Filter, 265/17 GY Fortera's.
