2009 to 2014 F-150
Old Wed, December 30th, 2009, 05:40 PM
martinoledad's Avatar
Default does tow/haul=overdrive
i was just wondering if the Tow/haul button was the same thing as the overdrive button on the older models.
Old Wed, December 30th, 2009, 06:20 PM
shotgun's Avatar
shotgun shotgun is offline
Gryphon CTS
The best I can figure out it's also different shift points, lock up points, and shift delays. In short, it's a completely different shifting strategy. It also provides engine brakeing.
The manual provides a lot of good information.
Last edited by Power Hungry; Fri, January 1st, 2010 at 04:08 AM. Reason: We prefer not to break engines. ;)
Old Wed, December 30th, 2009, 06:42 PM
Good job Shotgun!
Ford has copied GM on this one. GM has been running a set up like this since 2003. At least they have on the HD gassers.
Old Wed, December 30th, 2009, 06:46 PM
shotgun's Avatar
Gryphon CTS
Even a blind squirrel finds a nut once in a while.
Do you think they change the AFR too (richer)?
Old Wed, December 30th, 2009, 07:45 PM
Holy Cow! What a great modification! Makes me ALMOST want to run right out and get a new truck! Then I think of the payments and....
But, it's clearly NOT the same thing as the overdrive button. That only locked out 4th gear. As far as I can tell, nothing else changed.
They could have easily set the A/F ratio a bit richer too, as long as they stayed within EPA guidelines.
And, shotgun, super research! Good on you!
Old Wed, December 30th, 2009, 08:11 PM
ok thanks for the info
so is the overdrive automatically on
Old Wed, December 30th, 2009, 09:29 PM
shotgun's Avatar
Gryphon CTS
You're welcome.
Based on my towing experience, yes it is. When I'm towing my 4000 lb boat on level roads, I have seen the same RPMs (around 1800 at 65 mph) as when I'm not towing. However, it does take longer on a flat road (with steady throttle position) to get to OD and it doesn't take much additional throttle to get it to drop out.
Note that I do have a 3.73 LS rear end.
Old Wed, December 30th, 2009, 10:28 PM
i have the same rear end
Old Wed, December 30th, 2009, 11:31 PM
In GM's they don't.
Alls it boils down to is different shift strategies and torque management that are both electronically controlled.
Old Thu, December 31st, 2009, 12:53 PM
You're welcome.
Is there a way to lock the OD out? Possibly a D1, D2 position for the shifter? I can see how this would be desirable if the transmission was constantly shifting up and down. But, I've never been one to subscribe to the adage: "Don't tow with the OD on." If lower gears aren't needed, might as well save gas.
