Old Sun, January 10th, 2010, 01:35 PM
rufaast rufaast is offline
rufaast is on a distinguished road
Default Smoke Tune tuning on Check Engine light
Installed 6pos. chip, stock , 60DD, 80DD,smoke, 120race, 65tow.
So far love the tunes, 80DD pulls hard, of course the 120 race , lets just say . Smoke tune , not getting as much smoke as i would like would have liked to see more but the issue is, when i am in smoke tune, roll into the throttle the check engine light comes on, spiking 25psi boost. engine light will stay on for about 1-2mins and then go off.
Can someone tell me what this code might be?
thanks,
Old Sun, January 10th, 2010, 01:51 PM
It's hard to say. Bill usually lowers the desired injection pressure under higher loads/RPM on the Smoke Show tunes.
I would venture to say that the ICP is lower than desired (P1211 Code) but without actually scanning it, it's impossible to say for sure. You may have an overboost code, but some trucks don't turn on the check engine light for that.
Old Sun, January 10th, 2010, 02:01 PM
Default ...
Is the lower ICP going to hurt anything? Or is over boost is that going to hurt anything?
when does the over boost trip the chk engine light? how many psi?
Old Sun, January 10th, 2010, 02:18 PM
Lower ICP won't hurt anything.
The overboost usually trips between 22-25 PSI but a defuel will occur under most circumstances in the case of an overboost. Do you have a 99-03 or a 95-97 truck?
Old Sun, January 10th, 2010, 07:43 PM
Default ....
I have a 2000 F250 4x4,
wicked wheel
adreline oil pump
k&n intake kit
boost,pryo,trans temp gauges.
so in a defuel, or over boost, is it going to hurt anything,
I have the resistor to install on the map sensor, but have not done so yet.
should I , or just not worry bout the engine light,
Of interest, i havent had the check engine light come on using the 120race setting..
thanks for your responses.
Old Sun, January 10th, 2010, 08:30 PM
Bill may have disabled the overboost code in the 120 program.
You definitely shouldn't be having low ICP with an adrenaline so rule that out.
A defuel due to overboost won't hurt anything but performance.
Old Sun, January 10th, 2010, 11:31 PM
ChuckD's Avatar
ChuckD ChuckD is offline
Duty, Honor, Country
I am not a fan of installing things to fool the PCM. If you want things changed, change them in the programing.
Chuck
1995 Mustang GT
2004 Explorer Limited
Old Sun, January 24th, 2010, 06:40 AM
ttford07's Avatar
ttford07 ttford07 is offline
building FarmBoy monster
ttford07 is on a distinguished road
i would bet its ur over boost code, i have a 2000 also, i have an ats turbo and adrenaline, i throw the code in smoke, 120, and 140. i have a plug in fooler but i only run it when in competition. make sure ur pcm board is good and clean and that ur chip is secure, mine wiggle loose and that really made a diference, so i hot glued the corners
Old Mon, January 25th, 2010, 11:30 AM
I get overboost codes occasionally too. havent changed the trigger limits to eliminate them ... and you won't hurt anything if that is the code. a scan tool will get u the codes and a good one lie AE with ford enhanced will give you the data that caused the code to set
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
