Old Mon, February 1st, 2010, 08:18 PM
DIRTBIKEZ DIRTBIKEZ is offline
DIRTBIKEZ is on a distinguished road
Default EBP influence on tuning.
Just crossed my mind, I've had my exhaust back pressure sensor disconnected almost forever to keep the EBPV from closing. Is this having any effect on my tuning? Thanks.
Old Mon, February 1st, 2010, 08:26 PM
Is the EBP sensor disconnected, or the EBPV solenoid disconnected?
Old Mon, February 1st, 2010, 08:32 PM
The EBP sensor itself is disconnected, its easier to reach than the connector on the pedestal.
Old Mon, February 1st, 2010, 08:48 PM
I think that the EBP can effect alot of things with the shifting, but with the connector completely disconnected the computer will ignore this sensor and revert to the MAP sensor to alter shifting/ firmness, etc.
I dont know if it will be enough to make a noticeable difference.
FWIW I have had my sensor remove from exhaust system (still hooked up electrically just no pressure reference) for quite awhile and had not notice any changes.
Old Mon, February 1st, 2010, 08:55 PM
I appreciate the quick reply. I'd like Bill to confirm that there is no negative effect with the sensor disconnected. If I didnt have a 5" stack, the ebpv would still be operative.
Old Mon, February 1st, 2010, 09:21 PM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
See this thread here: http://forum.gopowerhungry.com/minot...706-boost.html
Light discussion about the EBP sensor, notice Bill doesn't say anything bad about having it disconnected. The PCM is able to use the MAP sensor in place, although not designed, because in an ideal world, EBP=Boost, although not so typically. So it is the next best thing when the computer can't "see" the EBP sensor. I've read of people trying to achieve a 1:1 ratio between drive pressure and boost. I'm guessing this would be for reaching peak efficiency. Feel free to correct me if I'm wrong.
Thomas H.
Old Mon, February 1st, 2010, 09:50 PM
hood stack?
Old Tue, February 2nd, 2010, 02:13 PM
The PCM only makes a few calculations based on EBP.
Backpressure valve
Shift/line pressures
Desired boost (which indirectly changes wastegate operation)
There's probably one or two more that I've forgotten.
Anyway, there won't be any real negative or detrimental effects of having the sensor unplugged. Auto manufacturers often implement strategies to avoid damage in case of sensor failure anyway (fail safe modes).
Old Tue, February 2nd, 2010, 03:49 PM
Bills last statement "If you turn the EBP sensor off in the program, the PCM uses MAP instead. That what the YEBP switch is for." I would take that to mean I need my programs tweaked.
hood stack?
No, just a traditional single. I havent actually heard it but I can only assume it to be obnoxious during high idle with the valve closed.
Backpressure valve
I guess I was really wondering if I was missing out from a performance stand point.
Old Fri, February 12th, 2010, 02:31 PM
oasis04's Avatar
oasis04 oasis04 is offline
Jet Driver
oasis04 is on a distinguished road
On a semi related note.
My calibrations are with the oem flattened turbo down pipe. I am getting ready to install a 3" down pipe to a 5" straight pipe into a single 7" stack.
I am wondering if I need new calibrations all together to accomodate this change.
Jeff
Semper Fi!!!!!!!!!!!
'97 F350 CCLB SRW 4X4 ZF5
DIY 6637 intake
FPR shim
3" down pipe 5" straight pipe 7" stack
PHP 6 pos chip
pillar pod 3 gauge (fuel pressure, EGT, Boost)
08 Console
Nitto Terra grappler 295/75/16
