Old Mon, February 8th, 2010, 12:59 PM
ttford07's Avatar
ttford07 ttford07 is offline
building FarmBoy monster
ttford07 is on a distinguished road
Default lots of questions
I bought an edge with atitude for my 7.3 bdcause i wanted the screen display. can i run the edge with my php tunes, I know wont really gain anything but will it hurt? seconf question is I may be converting my truck into a six speed, can i run my php chip still, im gonna be doing alot to my truck over the next 6 months and dont feel like sending it back twice when im gonna do injectors later on. thanx
ats turbo housing-Xwheel-1. exhaust housing, itp reg kit, 6637, ccv, adrenaline, 4'' straight to dual 5'' stacks out the back, gauges boost ,egt ,fuel, termi scan gauge, 6spd conversion, 238hybrids, beans tunes
434hp on mobile dyno
Old Mon, February 8th, 2010, 06:23 PM
KT Performance's Avatar
KT Performance KT Performance is offline
352-636-0812
KT Performance is on a distinguished road
You can use the attitude for your gauges.
My suggestion would be for you to purchase the chip and burner. Then you can reburn the chip your self. When you do injectors, you can have the custom tunes emailed to you.
Let me know if I can help.
Thanks,
Kenny
352-636-0812
Old Mon, February 8th, 2010, 08:49 PM
ttford07's Avatar
Ive already have the phoenix chip, been runing it since the end of december. Just wanted to know if I can stack the edge infront of it? and I know it can be reburned easily for manual and that a normal auto pcm can be run on a manual just throw a code, so will the chip need to be reburned right away?
Old Mon, February 8th, 2010, 10:09 PM
No "stacking" allowed!
Sure, you can run the attitude with your PHP tunes. However, you're just taxing the daylights out of your HPOP making it try to keep up with the demand (and the demand is a lot bigger now with your tunes).
I'd set the attitude on stock and use it as gauges though.
Old Mon, February 8th, 2010, 10:52 PM
ttford07's Avatar
dnt you think ur adrenaline pump can handle it? when i plugged my truck in to auto inginuity on lap top, in the 140 hp setting slowing reving it up till it was to the floor my icp pressure only hit 2300, that was sitting in park
Old Mon, February 8th, 2010, 11:04 PM
What does the mass fuel desired say?
You'll never get max PSI out of it by free-revving since there's no load.
Old Tue, February 9th, 2010, 12:45 AM
ttford07's Avatar
Sorry I dont remeber that, ill have to hook up and and go out for s drive and load it up. As for the auto-manual thing will my tunes still be ok for now?
Old Tue, February 9th, 2010, 08:42 AM
Yes, your tunes will be just fine as long as you use your present PCM. You WILL have a check engine light and a ton of transmission-related trouble codes though. The truck will run.
Old Sun, February 14th, 2010, 02:06 PM
ttford07's Avatar
just going to prolly use the edge as my gauges, is there a way to set the dge on manual tranny so if i do turn it up the edge will not mess with the php tunes for the tranny? maybe its obvious I just have not received the edge yet and was sittin around thinking about that
Old Sun, February 14th, 2010, 07:22 PM
The Juice does NOTHING for the transmission no matter which way you slice it.
