Old Mon, February 8th, 2010, 07:01 PM
Hidden Valley
Default Tire size adjustment..
Got my 87 Custom Perf loaded up and I went into custom options to fix my tire size and though I got it close...didn't get it quite right. I am showing about 2 mph higher then what my GPS says...so I over shot it a little bit. My question is...#1- would you worry about being off that little bit? #2- if I want to adjust it, can I go back into my custom options without going through the whole loading process again?
Old Mon, February 8th, 2010, 07:12 PM
shotgun's Avatar
shotgun shotgun is offline
Gryphon CTS
This will answer your question re: Custom Options.
http://forum.gopowerhungry.com/faqs-....html#post9248
As far as speed being 2 mph off, it's really up to you. There are numerous posts and very good methods for determining the corrected tire size.
Old Mon, February 8th, 2010, 07:28 PM
Hidden Valley
Thanks a lot for that link..lots of useful info there. Seems like I am fine with being 2 off on my dash. Gryphon and GPS are "almost" dead on. I'll just leave it. Thanks again. And just fyi to all interested, 2718 is what worked for my 35x12.5x18's
Old Tue, February 9th, 2010, 11:34 AM
That figure is just a teeny bit larger than what you'd get with a 3% "squish" compensation. Looks like a perfectly reasonable number to me.
Old Tue, February 9th, 2010, 03:30 PM
If you want to get it perfect clear the odometer on the truck and GPS, drive at least 10 miles then use this calculation:
Truck distance / GPS distance x tire size = new tire size
Also apparently Ford made the speedometer about 2 mph off.
My GPS, truck and gryphon all say the same thing.
