Old Sun, February 28th, 2010, 11:23 AM
Default Questions before purchasing the Gryphon
I want to get the Gryphon right away.
I am assuming I am running lean since I have a CAI on my 04 f150 5.4L
I am told I will need a custom tune for this.
But anyway, will I be ok running it with the Gryphon until a custom tune comes in? It takes 4-6 weeks afterall.
And my other question.
Can I order just the stock tunes for now on the Gryphon, and then later get some custom tunes, need an 87 economy tune and 87 performance tune, with them still being only 30 bucks each. Or is that price for only a new order on the Gryphon. So, if I get the Gryphon with no customs, and then later decided to get a custom, the price will probably be around 60 bucks per custom.
I only have CAI and exhuast ATM. No plans on upgrading anything else until the end of the year.
Old Sun, February 28th, 2010, 11:33 AM
It's my understanding that to get the $30 price, you have to pay for the tunes when you order your Gryphon. You CAN always get a Gryphon with the canned tunes on it though. But, because you have the CAI, you should really have custom tunes (you don't need three, just the one you use for daily driving would be fine).
The recommendation is to use the Level 2 tow tune until you get a custom tune (since it's richer) and to try to keep your foot out of it (don't do Wide Open Throttle runs).
Old Sun, February 28th, 2010, 11:35 AM
Thanks for the info. I understand that.
Is it possible to get an economy tune? Or is that what the tow tune is for?
Because I do not see that as an option.
Old Sun, February 28th, 2010, 11:40 AM
It is certainly possible to get an "economy" tune. It's what I have loaded into my Level 1 position. In general, it's just a non-towing performance tune with somewhat altered part throttle shift points and MAYBE a slightly changed "fuel map".
All you have to do is say that you want an "economy tune" in the remarks section of the order form and Bill will write it that way.
The tow tune is designed for pulling loads greater than 2500#. It is different than an economy non-towing tune.
Old Sun, February 28th, 2010, 11:46 AM
Alright.
I guess I had more questions than I thought.
What do I put down for my exhaust diameter?
I have Borla split rear
it comes into the muffler at 3
and when it splits into 2, it goes to 2.25
Old Sun, February 28th, 2010, 12:19 PM
Alright.
I am not any kind of authority on exhausts. I suspect the 3" figure would be the correct value though, because it's a "choke point" (the narrowest part in the new exhaust). You're not going to get anything through the 2-2.25" pipes that doesn't go through the single 3" section first.
88Racing is more knowledgeable about exhausts though. He might notice this thread and chime in.
Old Mon, March 1st, 2010, 11:17 AM
If you have maintained the original stock "Y". This is the pipe that comes off the headers with the cats and o2 sensors and then merges together to the point where you'd put a cat back on.
If this is the case then just put down Borla cat back system 3" SI/2.25" DO.
But..........
If you split the "Y" and put truduals under the truck then Bill needs to know this.
Hope that helps.
Peace
Old Mon, March 1st, 2010, 06:17 PM
Thanks 88 =)
Old Tue, March 2nd, 2010, 10:08 PM
Help
Eh, sorry, but yet another question.
Does it come with 3 stock tunes? And when I get my custom tunes, will I still have access to the 3 stock + 2 customs. Or is it limited?
So I would have for my case;
stock tranny
stock 87-tow
stock 93-per
custom 87-per
custom 87 eco
Is this correct?
Old Tue, March 2nd, 2010, 11:51 PM
What the gryphon comes with is what we call "canned" tunes.
It's layout is like this.
0-Stock.
1-Tranny only. Canned.
2-Tow tune. Canned.
3-Perfomance. Canned.
The gryphon can never have anymore than 3 tunes loaded in it at any one time.
My layout is this.
0-Stock
1-87 Performance tow(custom)
2-87 Performance(custom)
3-Performance(canned)
Canned tunes fit a lot of different f150's but custom tunes only fit your truck.
So in your case.
stock tranny(don't need)
stock 87-tow
stock 93-per(do you want this or keep everything the same octane?)
custom 87-per
custom 87 eco
Just some ideas.
