Old Wed, March 10th, 2010, 06:15 PM
double j's Avatar
double j double j is offline
double j is on a distinguished road
Default gear ratios
does anyone now how to find out what the gear ratio is of a 2005 f150 4x4 stx it has a 4.6.
Old Wed, March 10th, 2010, 06:25 PM
Here's a list of OEM rear axle codes. You can find the code for your truck on your driver's door sticker.
19 = 3.55 open
H9 = 3.55 LSD
26 = 3.73 open
B6 = 3.73 LSD
27 = 3.31 open
18 = 3.08 open
25 = 4.10 open
B5 = 4.10 LSD
Peace!
Old Wed, March 10th, 2010, 10:38 PM
double j's Avatar
thanks again you would think that they would just list the gear ratio instead of code
Old Wed, March 10th, 2010, 11:13 PM
Gotta keep'm guess'n!!!!!
Old Thu, March 11th, 2010, 02:35 PM
double j's Avatar
im guessing that LSD is limited slip differential
Old Thu, March 11th, 2010, 03:02 PM
Yep LSD stands for limited slip differential.
Peace!
Old Thu, March 11th, 2010, 06:11 PM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
Well you've got your answer, but if you come across another Ford you don't have the codes for here is a way. I might be wrong on newer trucks, but for many years Ford had ID tags on a bolt for the diff cover. One might say "75W-140 SYN ONLY" and the other would have various information on two lines(model, build date, etc.), if you look at the bottom line, left most numbers is would give the gear ratio and limited slip or not. EX:
  • 3 73 = 3.73 open carrier
  • 3L73 = 3.73 limited slip
Thomas H.
Old Thu, March 11th, 2010, 07:39 PM
double j's Avatar
sweet
