Old Mon, March 29th, 2010, 09:34 PM
Bigwheel Bigwheel is offline
Bigwheel is on a distinguished road
Default Gryphon Dash Pod
For those of you that have the dash pod how did you afix the pod to your dash where it doesn't move? I tried double sided tape and that doesn't work.
Old Mon, March 29th, 2010, 10:17 PM
jebrs2 jebrs2 is offline
jebrs2 is on a distinguished road
The dash pod should just fit between the trim spaces. Line them up with the pod just slightly forward of it's eventual ending position, press down without too much pressure, and then slide it back toward the windshield. It should snap right in with no adhesive or velcro of any kind. I'll try and post a pic of my set up by tomorrow afternoon(2005 f150 fx/4).
Old Mon, March 29th, 2010, 11:19 PM
What year truck???????????????????
97-03+04H attaches differently than the 04-08 f150.
Old Tue, March 30th, 2010, 06:54 AM
Oops...2002
Old Tue, March 30th, 2010, 06:06 PM
texas offroading
bigwheel, i had this problem w my '99....i used super glue on the left flat side,back right corner, and at the left front curve that goes around the dash where the vent is.
g/l.
Let's go Wheelin!!!
Old Wed, March 31st, 2010, 12:06 PM
I initially had the old style pod for my Gryphon, and it does not "snap" into place securely. I found though, that it didn't really slide around either (at least not on my 2005 dash). Finally, I decided I wanted it to be sitting a bit more away from the vent and I put a strip of heavy duty double sided tape along the back surface of the pod (the area that's most forward on the dash) and that held it fine for me. You just really want to use the tape where two flat surfaces tend to match up well.
Old Tue, April 27th, 2010, 11:17 PM
Oops...2002
I had a 2001, and I used velcro on the flat side next to the door, just got some from walmart, and that way I could take it off if needed... Hope this helps. and personally I think the pod should have velcro included instead of that 2 sided tape!
