Old Fri, April 16th, 2010, 08:36 PM
wolfrace wolfrace is offline
You like apples?
wolfrace is on a distinguished road
Default Some one elses invoice in my package?
I recieved my FU package, TS chip, switch and burner today but there was someone elses invoice in my box? all the info was right on the outside. Did I get the right thing are all TS chips the same ie different model for different model trucks?
Before I get to installing this I would like to know I am installing the right thing..........................
2000 F350 4X4, 6"up w/ bilstein 5150s, 20"rockstars, 37" Toyo M/T
Mods: Power Hungy Performance FU, pyro-boost-trans, airaid intake, Zoodad, wicked wheel, turbonetics EBV del., IH bellowed, Riff Raff (FRx, HPx, PRI's, OCR, AIH delete, boots,ccv), foil del., 50 cent, 4" turbo back w/Magna flow, Derale, max AC mod, 05 grille, clear headlights, and led tails.
Old Fri, April 16th, 2010, 08:44 PM
I'm not sure but I'll leave a post on the moderator forum for Corey.
Old Fri, April 16th, 2010, 10:35 PM
You like apples?
Thanks Corey, Bill did send me my activation code. I didn't want to get to far, before I made sure it will work in my truck.
So the TS chip I received will work in my 2000 F350 7.3, are they all the same size. Let me know if you need the invoice # of what I received.
Would it be possible to get a copy, of my invoice.
Thanks for your help.
