Old Sun, April 18th, 2010, 10:16 AM
BACAMICK's Avatar
BACAMICK BACAMICK is offline
BACAMICK is on a distinguished road
Default edge evo
hi , i read about cai here and i do have 1, a kn with a number 3 on the edge tuner , does that mean ill be running lean ? cant the MAF display (mass air flow) – Used to determine air/fuel ratio::: tell me wats hapning ?
regards mick
Old Sun, April 18th, 2010, 10:19 AM
BACAMICK's Avatar
thanks in advance
Old Sun, April 18th, 2010, 03:35 PM
Mick, welcome to you, from halfway around the world!
The short answer is, you COULD be running lean, but I'm not sure. We need Bill's input on this. I understand you have an F-250, but what year and engine does it have?
The problem with most commercial CAIs is that they change the environment around the MAF sensor, so it can't really give an accurate reading to the PCM. It basically may not be able to "see" the increased airflow, so you can get a lean running engine.
As I said though, I don't have a definitive answer here, because I'm not at all familiar with the effect of a CAI in an F-250. With luck, will get someone on here who knows more. Again, though, what year is your truck and what engine do you have.
Old Sun, April 18th, 2010, 08:52 PM
BACAMICK's Avatar
sorry about that , its a 2003 5.4
Old Mon, April 19th, 2010, 09:58 AM
If it's a 5.4L, 2003 model year, it SHOULD be fine. The "lean" problem was most common in the 04-05 models. I think you have a different MAF arrangement. But, you probably aren't getting all that you could out of the truck with the canned tunes.
