Old Thu, April 22nd, 2010, 01:15 AM
hemicross hemicross is offline
hemicross is on a distinguished road
Default Need help, cant read "box code"
I tried getting in there with a flashlight and a butter knife but I can't see the thing at all, is there another way at doing this? does the PCM pull out just a little?
Old Thu, April 22nd, 2010, 01:20 AM
is there a way to retrieve the box code using an OBDII scanner?
Old Thu, April 22nd, 2010, 01:44 AM
What year truck? If it's a 99+, you can unbolt the back of the PCM case (by the parking brake), push the back of the case towards the brake pedal about 25 degrees, and then yank back on the case. The PCM will stay in place but the case will slide back. You should then be able to see a black, plastic cap with the box code of the PCM on it. If not, then you might remove the PCM harness connector and take the PCM the rest of the way out.
Most OBDII scanners don't provide the calibration code in the PCM. It depends on what your using. If there is any option such as vehicle information, calibration information, software level, or anything like that, you might be in luck. Nearly all strategies will begin with a "V", such as VNAA4S2 or VHAE9J2. It may also begin with a "T", such as TNAA4S2.
Let me know if we can be of further assistance.
Old Thu, April 22nd, 2010, 02:11 AM
oh yeah forgot to include that, it's a 2000 ford excursion, i'll see if i can pop that sucker out
Old Thu, April 22nd, 2010, 02:48 AM
nice i was trying to get it from the engine bay, i just checked out under the dash and just had to undo two small bolts then the box brace released to the right and slid back, and on the edge of the box was a smaller sticker with bold letters and number, nice, thanks alot for your help
Old Thu, April 22nd, 2010, 03:27 AM
Glad to be of assistance.
