Old Mon, May 3rd, 2010, 10:24 PM
chris 0. chris 0. is offline
chris 0. is on a distinguished road
Default VDH2 match VDH4?
Will a fu chip programmed for a vdh2 work in a vdh4 pcm?
BOTTOMS UP!
Chris 0.
Old Mon, May 3rd, 2010, 11:24 PM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
Yep, it sure should. I checked and you're good. What are the plans?
Thomas H.
Old Mon, May 3rd, 2010, 11:40 PM
:what did you check? i bought a used fu package. so i lucked out and got a plug and play?
Old Mon, May 3rd, 2010, 11:53 PM
F-127's Avatar
Tuner novice
There is a spreadsheet on the website which has the PCM codes and other information such as part number, file name, and the important hardware type. The hardware type determines whether or not the chip will work on different vehicles. If they match, your set. If not, well, you'd need to be set up with different files. You should be able to plug and play, but you will likely have to pay something to be setup to download the files off the server and re-burn the chip in the future.
Thomas H.
Old Tue, May 4th, 2010, 12:01 AM
yeah that is fine. im very happy i dont have to send it to php! i get to play with it! this is my first chip i will be putting on my truck.
THANKS FOR THE GOOD NEWS!!!!
BOTTOMS UP!
Chris 0.
